07-31-2021, 09:05 AM | #1 |
Rep 17
550i lowering springs - chassis function limited
Hi guys I'm hoping I can get some answers to my dilemma.
I have a 2021 LCI M5, decided to install the H&R 550i Springs on my car. Looked like the install went great, car looks absolutely amazing dropped. The car drives fine but I got a message Chassis Function Limited ( Continued Driving Possible). The car drives absolutely fine with no issues Here is what I noticed obviously the light Chassis function Limited is on when I drive over 10mph I can NOT disengage the DCS it is constantly on, when I try to switch to m1 or m2 it will not engage because traction will not disengage when the car is at a complete stop I can shut off DCS and Traction. Please Help Please help |
08-01-2021, 10:33 PM | #4 |
12972
Rep 18,717
It is 100% installation issue.
I bet you the installer forgot to plug-in the EDC connection on the rear. Hopefully nothing worst.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
soooma1377.50 |
08-04-2021, 01:15 PM | #5 | |
114
Rep 282
I had about 6-10 codes blaring when my car was dropped with the KW adjustable, getting the alignment done (steering straight is of utmost importance) and sensor recalibration will solve it |
08-05-2021, 10:44 AM | #6 | |
42
Rep 221
r33_RGSport12972.00 |
08-05-2021, 10:45 AM | #7 | ||
12972
Rep 18,717
08-24-2021, 03:46 PM | #8 |
84
Rep 311
I’m having the same issue after lowering my 2020. Why did you have to replace the sensor? Was it damaged during install?
10-04-2022, 01:14 PM | #9 | |
112
Rep 216
76 Vertical dynamics management 2 errors 4828F6: Valve coil - rebound - rear right open pipe 4828F7: Valve coil - rebound - rear right short circuit valve Last edited by CrashCade; 10-04-2022 at 02:02 PM.. |
10-04-2022, 02:05 PM | #10 |
5234
Rep 10,616
If not very careful, the strut end the harness can come out of its little groove in the strut top and instead sit on top of the strut and be crushed as the strut top is bolted to the chassis. As you push the strut up into the hole you are working somewhat blind and the plastic fender liner can catch on the harness, causing it to come out of the groove.
10-04-2022, 07:03 PM | #11 |
59
Rep 136
I had the m550i springs installed on my m5 2 months into having it. definitely an install issue. we have an electronic suspension system. hopefully no wires were punched during install or maybe they forgot to plug in a sensor. getting an alignment is a good idea. it's covered under warranty before the first 1500 miles. just tell them i feel the car pulling to a side & you'll get a free alignment after your install.
10-06-2022, 11:02 PM | #12 | |
112
Rep 216
