07-27-2021, 12:25 AM | #1 |
86
Rep 263
Exhaust Valve/Flap
Hi Guys
So after picking up the new 840 GC on Saturday (pictures in other post). Was wondering if there was a way to keep the exhaust valve/flap open like it is on a cold start all the time? - there is a mod you can do on the g series where you unplug the control chip thing from under the exhaust once the valve is open - is there the same thing under the 8ers? |
07-27-2021, 05:59 PM | #2 |
Z
46
Rep 131
Sure, you can unplug it while its open, but it won't give you the noise that you want and I suspect it'll throw an error code.
If you want to get some good sound out of your car I would get an exhaust system. One thing I don't suggest doing is getting a "custom" exhaust (resonator delete, muffler delete...) Unless its done by a professional who really knows what they're doing, its bound to sound shitty/cheap. So my suggestion is to get an axleback/catback from Remus (for example). It won't affect your warranty since you're not touching the cats. It will give you the sporty noise when you want it, and it will shut up when you need it to since it retains the stock exhaust valve |
07-27-2021, 10:28 PM | #3 | |
4316
Rep 4,377
Drives: 2020 M850i Coupe
I toyed with doing it on my 2020 M850i coupe but ultimately didn't primarily as the cold start sound is not a major factor for me. Even after BMW neutering the M850i stock exhaust sound in early 2020 with the 03/2020 iDrive release (hit me via an OTA to 11/2019.60 in June of 2020) I still get enough enjoyment out of the exhaust sound once the car is warmed up with my Sport Individual setting that includes the Engine on Sport Plus. If I wanted more then that is where an after market exhaust comes into play, e.g., AC Schnitzer, etc. but the options are limited on a M850i and likely more so on the 840i. |
07-27-2021, 10:41 PM | #4 | |
4316
Rep 4,377
07-28-2021, 04:30 AM | #5 | ||
86
Rep 263
Thanks again! |
07-28-2021, 04:01 PM | #7 |
86
Rep 263
07-29-2021, 01:38 AM | #8 |
188
Rep 117
As an easy alternative. Check to see in your fuse box right side of the trunk, you should see a 7.5 amp fuse in position 213 I believe. It's the only 7.5a fuse on that block. If so, start your car in Sport or Sport plus, wait until the valve is fully open using a flashlight to confirm. It usually takes about 30-40 seconds. Once its open, simply pull the fuse out and the valve will remain open all the time. This works on my M850i and many others.
2019 M850i Coupe
07-29-2021, 04:41 PM | #9 | |
86
Rep 263
07-30-2021, 05:04 PM | #10 |
Z
46
Rep 131
Check out this thread if you're considering a new exhaust
Fi EXHAUST 8 Series Puzzle 840i / M850i and M8 / Competition X Zacoe Aero Kit https://f92.bimmerpost.com/forums/sh....php?t=1810776 |
jav_ski86.00 |
