Converting a converted AWD back to AWD from RWD conversion
07-26-2021, 07:33 PM | #1 |
Rep 31
Drives: E28 1984 533i, E92 2007 335i
Hey, new to the site, wanting to buy a e90 335xi that was converted to a RWD the current owner says they did to handle to power better from the modifications they made. I am dead set on the AWD for year round fun and I wanted to know how imersive that project would be, around how much, and the best outlet to purchase said parts to achieve my goal. Just trying to be prepared when I bite the bullet on purchasing this car, the only thing I need to do is look at it and drive it home if it is truly the one. Any and all information will be greatly appreciated! Thanks!!
07-26-2021, 08:53 PM | #2 |
638
Rep 766
It depends on what was done.
To maximize the benefits (eg weight reduction) the front subframe/oil pan may have been swapped over to a 2wd set. It's also possible the transfer case was removed and gearbox swapped. You'll probably need a donor car out of a junk yard to get all the parts you need, and only heaven knows what wiring was stripped out. It's more likely the previous owner just ran the X-delete software flash, and removed the front driveshaft. That's pretty easy to reverse. From experience... It's usually a whole lot more trouble than one expects when purchasing somebody else's Frankenstein.
Sometimes a bolt is just a bolt.
07-26-2021, 09:49 PM | #3 |
Rep 31
I think that sounds more like what the owner was talking about. I guess that doesn't seem nearly as bad as I thought, that way I can put it off til the end of the summer to enjoy the RWD til the shit hits. Thanks!
07-28-2021, 09:55 AM | #4 |
1306
Rep 852
Highly doubt he actually swapped the front subframe and oil pan and all that. Most likely he did as said above or might have gone a step further like I did and remove the two front axles. You could see if this has been done pretty easily looking down the engine bay. Many people do this once the system fails and they never wanted it anyway so they get rid of it like I kinda did.. so beware of issues after putting it back together because it might not even work.
Airplane Mechanic
BMW Masochist |
07-28-2021, 06:18 PM | #5 |
Rep 31
Right on, thanks for the advice. I'm hoping that that's not the case since like I said above that he told me it was to handle the power better because every bolt on modification that can be done has been done to this car, I wouldn't doubt that he even upgraded the internals and just forgot to tell me. So I've got my fingers crossed, having an AWD vehicle has been a major goal of mine and I can't see myself getting a truck or SUV type vehicle.
07-28-2021, 06:20 PM | #6 |
Rep 31
I guess worst-case scenario I buy it and instead of a 335xi i just get a 335i, but at this point in my search for one I'll just have to like it.
08-05-2021, 08:16 PM | #7 | |
Rep 6
Drives: N54 335i xDrive
08-06-2021, 06:49 AM | #8 | ||
1306
Rep 852
Airplane Mechanic
BMW Masochist |
