07-15-2021, 01:54 PM | #1 |
32
Rep 31
Drives: BMW M2 Competition
Rock to the AC Condenser=$2700
Hey Everyone...was driving on Tuesday and heard a hissing noise from my vents followed by no more cold air with the AC on. Took it to Winslow BMW in Colorado Springs - a rock missed my Dinan heat exchanger by 1/4 inch but did hit the top left of the condenser and now it's done. The tech says this is ultra rare, but the bill is just under $2700. Just FYI if you run into this...it took several hours for them to locate the leak.
07-15-2021, 03:09 PM | #2 |
1410
Rep 1,803
A rock took out my stock heat exchanger and my dealer incorrectly diagnosed a leaking radiator as the source of the coolant smell. So they replaced the radiator under warranty (??).
After additional cold weather, the leak got bigger to where I can see it easily in the heat exchanger. I ended up swapping the heat exchanger myself, since there was no way my SA would approve that under warranty. It wasn't nearly as expensive... but rocks suck.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
