07-12-2021, 11:51 PM | #1 |
195
Rep 612
Testing
I wanted to test my 2021 M5 Competition before I started modifying it. I was impressed for a stock car and completely full tank of fuel. Top end was sluggish compared to my stage 2 E63 but overall strong results. Hope to hit 10.3-10.4 this year and break into the 9’s next year. That is assuming someone cracks the 2021 ECUs besides Mission.
For comparison my best time on my 2018 E63 was 10.40 at 133. Stock turbos, downpipes, DME tune, methanol, CPC. |
07-13-2021, 12:01 AM | #2 | |
71
Rep 185
Drives: 2022 X6M
07-13-2021, 12:58 AM | #3 |
195
Rep 612
07-13-2021, 01:28 PM | #5 |
239
Rep 407
Nice run. Looks like a great launch going under 1.7 seconds for the 60' on a surface with no prep. Also, excellent et particularly when you were at almost 1,000' altitude.
The trap speed does look slightly low for an et under 10.8. At that trap, I would have expected closer to 130 mph. What gas were you using. |
josec704074.00 |
07-13-2021, 07:49 PM | #8 | |
195
Rep 612
I used shell vpower 93 but literally filled up one day before so tank was absolutely full. I usually like to make runs between 1/4-1/2 tank. I have 102 close to me along with E85 so I will do a lot of testing with fuel mixtures to see what works best. I will update the group. I’m documenting everything in a spreadsheet so no guessing for me. |
Jamesmick131.00 |
07-13-2021, 07:50 PM | #9 |
195
Rep 612
07-13-2021, 07:52 PM | #10 |
195
Rep 612
07-14-2021, 12:59 AM | #12 | |
239
Rep 407
You have removed between 90 and 120 pounds of unsprung, rotating mass versus the average M5 (assuming steel brakes and depending on whether you measure against the stock boat-anchor cast wheels or the lighter buts still porky forged wheels). That is huge and I deeply envy your HREs, but could not justify that expense for myself ;-). |
07-14-2021, 04:43 AM | #13 |
876
Rep 1,319
I’ve seen multiple tests, where the pre LCI has been inconsistent in its launches. The LCI seems to have addressed this. To add, I’ve not had problems with launch on pre LCI, just conveying what others have found and reported.
07-14-2021, 08:00 AM | #14 |
MFJWADE
120
Rep 351
Nice, the lighter brakes and wheels do help with the short times. Do you have sunroof or carbon fiber? It too makes a dif in the overall package. I have a 2018 with no sunroof and CCBs and it gives me a lil edge in the numbers.
07-14-2021, 09:54 PM | #15 |
195
Rep 612
Carbon roof. I tried to build a lightweight M5 without compromising anything I wanted. Executive, full leather, and CCB
07-14-2021, 09:59 PM | #16 | |
195
Rep 612
I don’t think I ever owned any vehicle with the stock wheels so I definitely have an addiction |
07-17-2021, 05:14 AM | #17 |
195
Rep 612
Map 2 (Stock downpipes, Shell 93). Getting my downpipes put on next week but I hope I can test Map 3 running 102 before the install to set a baseline. I’m guessing I run 10.32 at 135 but we will see. I hope the downpipes help my times and won’t hurt them but I will test the same maps, fuel, road, and hopefully similar conditions and report the results. These cars seem to be finicky when running catless but hopefully Terry can square me away.
The 0-60 on this run was actually 2.69 but the slope made it invalid. The 2.70 was the 0-60 on Map 1 and I ran a 10.53. Last edited by apsuard; 07-17-2021 at 05:22 AM.. |
DrivenAgain120.00 |
07-17-2021, 04:54 PM | #19 |
195
Rep 612
Thanks! I appreciate it. I’m aiming to get a 10.30 so I’m the fastest 2021 M5 in the 1/4 per dragy. I just put in 10 gallons of 102 and hope to make a run tonight or tomorrow night. So damn hot and humid though.
DrivenAgain120.00 |
08-12-2021, 12:56 PM | #20 | |
114
Rep 282
So you nearly matched your E63s with the JB4 only???
