07-01-2021, 12:13 PM | #1 |
48
Rep 36
Pinout for Amplifier
I'm looking to add my own DSP to the car, since the major vendors are saying December/January at the earliest, does anyone have the electrical diagram, or know the pin out of the amplifier's output section?
I'll be using line-level inputs to a DSP, and then most likely running my own speaker cable to the speakers. Thanks! |
07-05-2021, 01:10 PM | #3 |
48
Rep 36
It is likely optical from the head-unit to the amp, yes; the iDrive7 system isn't MOST, so it's not as easy as getting a MoBridge device. Currently the only option is line-level outputs from the AMP into a DSP with input AND output EQ control.
I have a ton of gear prepped to build a SQL competition system, I'm trying to find a reasonable way to integrate a DSP and set of amps without modifying any wiring harness. |
07-16-2021, 12:33 PM | #4 | |
1166
Rep 2,180
