06-29-2021, 08:07 PM | #1 |
386
Rep 400
Reached the 100 launch control mark
I ve been noticing that my 0 to 60 dragy times are not the same compared to few month ago despite the tires hooking up well with the warm weather and then noticed that i can hear the farts when the car shifts after launching that means slower shifts and explains the slower 0 to 60 times
I hate BMW for limiting the launch control numbers |
06-30-2021, 10:00 AM | #3 | |
1923
Rep 2,012
Drives: 2022 i4 M50
I'm not sure I quite get the limit as you'd think the smoother/quicker shifts cause less wear, but I suppose my mind isn't computing what else is occurring to make those quick shifts happen.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
06-30-2021, 10:12 AM | #4 |
384
Rep 164
There is definitely a limit. BMW are not the only cars that have the limit. It's actually pretty common. Main thing is just becareful when buying a used M because you don't want to buy one that's been all used up.
Resjudicata1607.00 |
06-30-2021, 12:36 PM | #7 | |
4429
Rep 4,109
To date and as far as I'm aware, nobody has found a way around it including getting a TCU tune. Once you hit it, the ZF transmission disables one of the quickshift modes (QS 1, 2 and 3)--IIRC, QS3 is what's used for launching. Without it, you'll hear the bangs as the car shifts up and will feel the typical rebound from power loss as the current gear is disengaged to back on the power again as the new gear engages. Without it, I don't even bother taking my cars to the dragstrip since I lose almost 0.5s on the 0-60 and a further tenth or more on each subsequent shift. It's especially noticeable from 1st-2nd and from 4th to 5th. |
07-02-2021, 10:59 AM | #10 |
Rep 10
Is there a way to see how many times it has been done?
07-02-2021, 12:01 PM | #11 | |
4429
Rep 4,109
07-02-2021, 04:24 PM | #12 |
1607
Rep 2,937
Andycam55.50 KrazieJunkie18.00 |
07-02-2021, 04:26 PM | #13 | |
1607
Rep 2,937
each time it redlines, it could be manual or other reasons. but 2-3 redlines in a row at higher gears; is usually an indication on the report. but it's 50/50% guess. |
Publius29.00 |
07-02-2021, 04:42 PM | #14 | ||
4429
Rep 4,109
You're also citing a way to infer the launch count using the same approach as I'm saying can precisely show you the launch count—red line doesn't equate to launch, not even close. If you mash the pedal from a light, that'll count using your method. Not the same thing; not at all. |
07-02-2021, 04:45 PM | #15 |
4429
Rep 4,109
Thanks. Wasn't sure although it seems like a reasonable assumption.
07-02-2021, 07:02 PM | #16 | |||
1607
Rep 2,937
If you're on your own; either go to BMW, or get any report and try to guess the redline launches. |
Publius29.00 |
07-02-2021, 07:05 PM | #17 | |
1607
Rep 2,937
It's true across the entire line up. Everything that Audi, MB, and BMW makes with the launch counters. I've heard rumors about Porsche too, but I'm not sure about others. But it's a fact it's on all the BMW with transmission and launch counters. Also it's on most the AMG and IS lines. |
07-02-2021, 08:47 PM | #18 | |
56
Rep 82
As there is nothing in the owner's manual on this and the sales channel doesn't mention it, I wonder how this would play out from a BMW liability perspective. The manufacturer's stated acceleration times are with launch control I would assume, as you want to drive sales with the best stats possible. If I buy a new car (clearing the run-in period nicely for sake of argument) and do one launch a day, in three months the car would not perform as advertised anymore. Nothing would be broken, nothing would be damaged or wrong, it's just not performing as advertised. I have not violated anything the instruction manual says I shouldn't do. I wonder if a case could be made against BMW. A bit like Dieselgate when you buy a car with certain engine performance, and then out of the blue it gets detuned by the manufacturer. You don't get the product that you ordered and paid for. |
Publius29.00 |
07-02-2021, 09:18 PM | #19 | ||
1607
Rep 2,937
As for BMW, maybe. It's probably a tough case. You have to prove that you relied on that stat when you bought the car. And that you're impacted by it. For example, you have 3 other cars and you bought the bmw specifically for a drag strip race. You only use the car to race. And you race for money every time in an official sanctioned licensed racing events on a regular basis. Then it literally is costing you money and you're losing $$$ enough to make a serious lawsuit. That's an extreme example, but you get the idea. We need a real financial harm specific to the launch. |
07-02-2021, 09:25 PM | #20 | |
56
Rep 82
Okay, I hear from my own argument that it's time to get to bed and not get worked up by BMW news Note to self - no legal discussions at 4 in the morning |
Resjudicata1607.00 Publius29.00 |
07-02-2021, 10:28 PM | #21 | ||
1607
Rep 2,937
Under Virginia law, in the USA, in your example; even if you were right and proved everything; the courts would only award you $50 total roughly equal to the cost of paint. A typical attorney would charge around $5,000 before collecting and typically another 40-50% post collection work. Thus, you're painted room law suit would actually cost you roughly $10k in legal fees plus court costs to win a total of $50. In the states, we need to prove damages to recover compensation in tort type lawsuits. 4 key elements; duty, breach, harm and causation. It's a tough sled to show you need a whole new race car to launch; if you're not racing. |
07-03-2021, 10:37 AM | #22 | |
56
Rep 82
Makes sense what you are saying. Consumer law here is a bit different, you don't necessarily need to argue your case in court and the law is pretty clear on if a thing does not live up to the performance/quality you could reasonably expect. Ah well, next time my car goes to the shop I will at least try to get them to read the launch control number so I know what I am dealing with. My car had 590 miles on it when I bought it so if I'm unlucky a lot of those launches went away then Last edited by Andycam; 07-03-2021 at 10:39 AM.. Reason: Spelling |
