06-27-2021, 07:48 AM | #1 |
Rep 15
So, installed the AA EL midpipe. Drove the car for about a week and discovered the diffuser has melted. It's also starting to melt above the tips too.
The clearances are there, nothing looks different vs a stock M2 from a clearance/distance position. There is no areas of apparent contact either. I'm not sure what's causing it but I just dropped money on a new RKP diffuser to start all over again. I'm beyond frustrated. I'm not saying it's not something on my end with the install but the directions were followed to the letter by people that have put exhausts on before and aren't rookies. This is a new problem to them too. I'm not saying AA is to blame but I'm not exactly sure what could have been done different here. There isn't exactly a lot of leeway on moving this exhaust with the factory hanger/clearances. Also, you can maybe make the argument that perhaps muffler placement is too close, but the melting above the tips?!? That's not a spacing issue. That's something else. Last edited by RollingInDubs; 06-27-2021 at 08:25 AM.. |
06-27-2021, 07:55 AM | #2 |
351
Rep 1,681
First time I'm hearing this but this plus the tinny start up noises plus the 2 month wait makes me wonder if single midpipe was the way to go
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
06-27-2021, 11:36 AM | #4 |
125
Rep 97
Damn that sucks!
Just wondering though why AA Midpipe would be to blame if it looks like the melting is happening near stock muffler? Does installing mid pipe slightly change location, push back the muffler closer to diffuser? Or hotter exhaust gases due to all the wiggles in the midpipe |
06-27-2021, 11:57 AM | #5 |
253
Rep 179
I had mine ready to ship a few months ago and canceled it when they called for delivery options. Wasn't feeling confident with the information I was reading.
I ordered the EL non res and muffler. Went with the akra, obviously not the economic choice but I love the way it sounds and the fit was perfect. Videos don't do the audio justice.
-2020 M2Cs
-2020 GLS450 |
(K)1278.00 |
06-27-2021, 12:11 PM | #6 | |
351
Rep 1,681
Current: ///M2C
06-27-2021, 04:33 PM | #7 |
3024
Rep 13,763
possible that wherever you made the cut to mate the EL to the stock box, that it's pushing the muffler back further instead of being "neutral". I don't think that's AA's fault.
~loud noises~
BMW DIY Guy3075.00 |
06-27-2021, 04:56 PM | #8 | |
Rep 15
There's at least an inch gap all the way around between diffuser and muffler. See attached picture I took. You can see the distance between the muffler and the melted diffuser. |
StephGOD218.50 |
06-28-2021, 01:28 PM | #9 |
35
Rep 30
Ugh, I just went out on my lunch break to look at my car and it looks like I have the exact same issue…has only been installed on the car for ~2.5 weeks. I'm really confused as to what could have caused this…
06-29-2021, 09:38 AM | #11 | |
94
Rep 63
pawelczyk7139.00 |
06-29-2021, 09:50 AM | #12 |
3489
Rep 9,709
That's weird.
Potentially, removing the secondary cats makes the entire exhaust hotter ( rather than concentrated at the cats), maybe? Or, the steel used has a higher coefficient of expansion than the stock mid pipes. This in conjunction with the extra pipe length which will no doubt expand more because there's more of it. Probably means you need to cut the exhaust a little shorter than what AA suggest to allow for additional expansion. |
06-30-2021, 09:29 AM | #13 |
3075
Rep 3,022
Drives: 2019 M2 Competition
Just double checked mine.. single channel AA mid with resonated ABs, *cough* catless DPs *cough* with the standard exhaust.
I do NOT have this issue.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
06-30-2021, 03:39 PM | #14 |
45
Rep 54
It also happened , but not as bad as in your case . The exhaust expands a lot when it gets hot . In my case the installer had held the exhaust too far back to make the 4 tips stick out more . After positioning the exhaust further back it no longer touched the bumper . Unfortunately in your case you will have to buy a new bumper ( about 1.000 € ) and clean with sandpaper file the exhaust to clean it . While you're at it, paint it black. I have traveled 30,000 km after proper placement and have not had the problem anymore
Translated with www.DeepL.com/Translator (free version) |
10-03-2021, 09:26 PM | #15 |
1045
Rep 605
Drives: M2C
I'm afraid I realized that I've joined the club.
Pictures attached. Although I noticed today, I don't know how long ago this happened. I originally got it installed in March and drove around a ton. Then in May I painted the diffuser black using the recommended products on various threads about it. At the time I didn't notice any issues (looked underneath for several days after the install and no issues then either). Then today I got underneath again for the first time in about 5 months and noticed the damage. I'm at a loss for why/how it took so long to happen for me when you guys noticed the damage within a couple weeks of the midpipe install. I also don't know how big of a problem this is. I can't notice it unless I get underneath to take a look. |
10-05-2021, 01:52 PM | #17 | |
2432
Rep 11,667
changing pipes cannot increase heat. Heat is what the engine puts out & unless the pipes were insulated, the heat to muffler should not change This is 100% installation related. The exhaust will lengthen by more than 1" when hot, due to metal expansion when heated. If there is not enough gap from muffler to diffuser then the pipe will grow in length and make contact. As mentioned in one of the posts above... since one of the pipes is longer than OE, there is more material, thus greater expansion than stock. I would measure the stock gap before install, then add a bit to allow for increased expansion. If the tips are not extended out far enough, I would address that separately. |
///M TOWN16543.50 |
10-25-2021, 01:49 PM | #19 | |
47
Rep 89
inTgr8r2431.50 |
07-08-2023, 04:19 PM | #20 | |
275
Rep 617
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
07-08-2023, 04:28 PM | #21 | |
1045
Rep 605
Drives: M2C
With that said, the problem hasn’t gotten any worse. It’s still sad and ugly to look at when you deliberately look for it, but it’s not easily visible. |
07-08-2023, 04:32 PM | #22 | |
275
Rep 617
Whenever anyone sees my muffler, they always ask why it’s just smeared in black haha Also same, there’s no way I’d buy an expensive CF diffuser without taking care of this issue first. What I’m confused about is that my muffler tips don’t even stick out that much, so I don’t know how it’s even making contact. There’s about an inch gap in between my muffler and diffuser, but that may just be because most of it already melted off
