06-25-2021, 10:06 AM | #1 |
28
Rep 132
Help with JB4 Meth setup
I just had my Burger Meth kit installed but I’m not quite sure what settings to apply for WMI only to go along with my DME stg 2 flash.
I’ve gotten some conflicting and confusing info that this far has led to 3 days with the kit installed but not actually functioning😢. Could anyone with some JB4 expertise help me out? I’m just needing to know which settings to adjust to in order to run map 0 with WMI active. Current settings are Meth trigger 1 WMI Boost additive 0 Scaling 60 Min flow 8 Under Trigger section Min rpm 2000 Max rpm 7000 These were given to me by Mo at DME but there still appears to be no meth spraying. I’m waiting on word back from terry at BMS. Hoping he can point me in the right direction. Those guys are both pretty busy though so hoping I can get some info here. Thanks guys!! |
06-26-2021, 09:18 PM | #2 | ||
233
Rep 354
Drives: 335XI MPerformance edition
Try 5-7 or 3 if i remember.
E60 550 2007 - Grey // F30 2015 335XI MPerformance edition - Lacuna Seca Blue // F30 2015 335XI MPerformance edition - Grey black // F90 2018 M5 - Donington Grey |
06-27-2021, 06:23 AM | #3 |
5234
Rep 10,616
My understanding is that with the current firmware, you can run WMI on at least Maps 1-8. Map 8 is dedicated for meth use and offers the most control. I run it on Map 2 by setting Meth Trigger to 1 in the user adjustable settings. Should work on Map 1 as well. Map 0 is the everything off stock map so I would not expect WMI to work, but don’t know that for sure.
06-27-2021, 10:47 AM | #4 |
28
Rep 132
Map 0 is the only consistent setting I’ve heard from all parties so that is atleast correct. Not looking for JB4 to control or do anything other than WMI and apparently that is the map to do so
