ABS, Brake, traction control lights E90
06-23-2021, 12:23 AM | #1 |
Rep 4
I was driving and all of a sudden these 3 lights (ABS, BRAKE, Traction Control) came on. I read the codes with my obd2 scanner and it only read the check engine light which was unrelated (exhaust code) but the car still drives completely fine and smooth. Anyone had this problem before and found any solutions?
Been looking into it and came across all of these which could be the issues: -Drive shaft reluctor -Wheel speed sensor (front left?) -Steering angle sensor -Abs hydraulic pump -Wires (left side of engine bay)(front passenger wheel speed sensor) -ABS/DTC block module (valve body) -Transfer case module (white) -Ecu programing Let me know if you had this problem and the fix that solved it |
06-24-2021, 03:32 PM | #2 |
Rep 65
Hey mate,
Did your dtc switch off? Does switching on and off help? From what you mentioned its either a wheel bearing (there is a magnet that's used for wheel speed sensor) or the wheel speed sensor. I had both Pretty much 3 lights on and off randomly. In my case I replaced the 3 sensors (2 front and 1 rear). 2 Wheel bearings in the front also Hope it helps. Thansk, Alex |
06-24-2021, 03:36 PM | #3 | |
Rep 4
06-25-2021, 08:00 AM | #4 | |
Rep 65
Regards, Alex |
