11-04-2008, 07:21 AM | #1 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
Question on Alignment
Is the camber adjustable on the new E92 M3? I'm planning on lowering, but not sure about the spec on the car on adjustments. Thanks
11-04-2008, 09:10 AM | #2 | |
34
Rep 330
Drives: BMW (E92) M3 & 2004 JCW MCS
I have confirmed with my local BMW dealership in Brunei and ex-BMW dealership in Australia, that the camber can be adjusted at any Wheel services shop. My bro-in-law who owns a Tyre & Wheels services shop has recommended me the H&R springs for vehicles that have the EDC. Have a look at the link: http://hrsprings.com/scripts/appguid...|%20M3%20Coupe I would show you a pic of my vehicle but my springs are on order. Hope it helps.
Warm Regards,
Mischievous M No Replacement For Big Displacement! |
11-04-2008, 09:35 AM | #3 | |
///M Fan
366
Rep 2,159
Thank you for your response. That is actually great. I am ordering H7Rs as well. Just did not know if the canber was adjustable, now I know... Thank you for your help. |
11-04-2008, 09:46 AM | #4 | |
34
Rep 330
I suppose not worth having unless either one of us use our cars on the track. Sigh! wish we had a track in Brunei. haha!
Warm Regards,
11-04-2008, 09:56 AM | #5 | |
///M Fan
366
Rep 2,159
11-04-2008, 10:01 AM | #6 | |
34
Rep 330
What 19s will you be running? I tried a set of Breyton Flames on my car at my Bro-in-law's shop. They look insane but somehow, the stock 18s look pretty rad. Have a look and feel free to comment:
Warm Regards,
11-04-2008, 10:32 AM | #7 | |
///M Fan
366
Rep 2,159
11-05-2008, 11:04 AM | #9 |
///M Fan
366
Rep 2,159
11-05-2008, 12:29 PM | #10 |
98
Rep 1,043
11-05-2008, 12:50 PM | #11 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
On the e46, I used to run 2.25 degrees negative in the front and 1.5 negative in the rear. I also ran 0 toe in the rear and some mininal amount in the front. The settings worked really well in the front where my street tires (PS2s) went around 20k miles and my track tires wore evenly. It was a different story in the rear where I would eat a set of PS2s in about 8000 miles with more wear on the inside. I wore the track tires very evenly in the rear at twice the rate of the fronts.
KINGLEH, What were the camber and toe settings on your car before and after? I think I read that Dinan has something that can get you more negative camber in the front. 1.8 isn't very much for a combination street/track car. |
11-05-2008, 02:19 PM | #12 | |
1977
Rep 1,847
Did you go from neg 1.1 FC to neg 1.8 FC by replacing the stock springs with H&R springs? |
11-05-2008, 02:52 PM | #13 |
33
Rep 657
Sure is, I pushed mine to a little past ~1.4 or so. I'll check the exact specs.
-Dave
2008 E92M3-Space Gray Eisenmann Sport Exhaust_MT/Loaded |
11-06-2008, 08:22 AM | #14 | |
34
Rep 330
Pardon my ignorance but i was just curious if i needed/crucial to adjust my wheel camber settings once i change my stock springs to the H&R. Thoughts?
Warm Regards,
11-06-2008, 08:26 AM | #15 | |
34
Rep 330
so do you reckon i should upgrade to the Breyton Flames? My bro-in-law is extending a super generous offer to me but i am fighting temptation as hard as i can for now. I was criticized by a good mate that if i went to the the Breytons then i may as well give up the car cos i am spoiling the brand and exclusiveness of the M. What do you think?
Warm Regards,
11-06-2008, 10:01 AM | #16 | |
///M Fan
366
Rep 2,159
11-06-2008, 09:19 PM | #17 |
Moderator
673
Rep 4,737
From another thread:
11-07-2008, 02:23 PM | #18 |
1977
Rep 1,847
I don't think you'll need to adjust your front camber since you're not lowering the front by much.
11-08-2008, 05:33 PM | #19 |
13
Rep 260
The little bit of extra negative camber should be fine even for mostly street driving, but it is worth getting an alignment to reset the toe. If you have too much toe out in front turn-in will be very responsive (which can be nice), but tire wear will also increase quite a bit.
11-08-2008, 10:14 PM | #20 |
Moderator
673
Rep 4,737
Had my H&Rs aligned today.
The mechanic told me that the fronts are at -1.6/-1.7 and rears are at -1.7/-1.7, and cannot go anymore positive on the front unless I get camber plates. Toes are set to 0.2. He said that after the drop the front toe is completely off, but the rears are ok. |
11-08-2008, 11:03 PM | #21 | |
1977
Rep 1,847
11-09-2008, 12:00 PM | #22 |
21
Rep 362
For the references to front camber adjustment in this thread, I assume people are doing pin removal to change their non-lowered stock front camber. On the e46 it was good for about .5 degrees. Does anyone know what the e92 maxes out at using the stock slots without the pin?
