People with Dragys: What kind of times are you knocking out on street tires?
06-21-2021, 12:34 PM | #1 |
2002
Rep 3,731
Picked up a Dragy over the weekend...a fathers day gift to myself. I'm running 265/50/18Firehawk 500's in the rear which are a decent tire, but not as sticky as something like an R rated or drag-radial. The car is 6AT FBO running a Stage 2+ E40 tune with stock turbos.
Even launching in 2nd gear, and pedaling it trying to keep it from spinning as soon as the boost comes on, my 60ft times are horrible.....the best I was able to knock out was a 12.60 @ 117. With that trap speed and a decent 60ft, I should be in the mid/high 11's. The HP/TQ is there...but the traction isn't. Is there any way to get these cars to hook up on street tires? I'm running solid subframe bushings, and M3 rear arms. I don't get any wheel hop...just spin. edit: this was on a "closed coarse" section of payment
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
06-21-2021, 07:12 PM | #4 |
393
Rep 972
Nice! I have a xi auto (xhp) fbo MHD stage2 +.
I've always been curious what I would run in the 1/4 mile.
Instagram : @Bimmer_bro
06-21-2021, 07:28 PM | #5 |
2002
Rep 3,731
Honestly....I don't think it would. My car lays two big black marks on the pavement. The e-diff does a pretty good not of putting power to both tires. For a twisty road? Yes....an LSD would make a big improvement, but I can't justify $2k+ fo an LSD when the e-diff does really well on straight line acceleration.
Dave92N54528.00 |
06-21-2021, 09:08 PM | #6 |
63
Rep 124
Get xHP my friend, under the customized module limit your second gear torque limit to 400nm as a starting base…….you can adjust up or down 50nm to get the correct traction you want
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
06-21-2021, 09:22 PM | #7 |
63
Rep 124
This run is when I was running stock turbos with an E40 tune and second gear torque limit set at 450nm.
06-22-2021, 06:02 AM | #8 |
2002
Rep 3,731
I've got xHP...running stage 3. Haven't messed with any of the settings yet. Is it better to limit torque by gear using XHP...or boost by gear using MHD?
06-22-2021, 06:31 AM | #9 |
63
Rep 124
Use the settings threw xHP, boost by gear threw MHD does not work well.
06-22-2021, 07:34 AM | #10 |
449
Rep 823
My first attempt was a 13.0 @ 111. I was so disappointed. It only took a new clutch, turbos and a WOT Box to shave those 1.4 seconds off
2008 335xi 6MT - 16T China Turbskies - eBay FMIC, DP & CP - VRSF Inlets - SSR DCI's - Walbro 450 LPFP - RFP e85 Tune
Bimmer_Bro393.00 |
06-22-2021, 07:44 AM | #11 | |
393
Rep 972
06-22-2021, 08:09 AM | #12 |
449
Rep 823
It's a homebrew e50 tune based off a free RFP map. And I am no tuner, so I'm sure it could be better. What is clear is that you need to get a dragy and put your expectations to the test!
Bimmer_Bro393.00 |
06-26-2021, 08:08 PM | #13 |
202
Rep 449
This was my first and only attempt on the street with the new Sutphin flash. 94 + meth and snow tires (AWD).
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
06-26-2021, 10:26 PM | #14 |
449
Rep 823
06-27-2021, 03:11 PM | #16 |
2002
Rep 3,731
06-27-2021, 04:29 PM | #17 | |
202
Rep 449
Cheers.
06-27-2021, 09:36 PM | #18 |
2002
Rep 3,731
I think it's all in the tires.......these motor make so much torque, even 2nd gear launches end up spinning like crazy as soon as the boost comes in. And with the IRS setup...they don't really squat when they launch and transfer weight to the rear tires like a solid axle car. But.... they weren't designed to be drag cars.....
06-27-2021, 09:47 PM | #19 |
300
Rep 884
I can't believe I still haven't done a dragy run with my 335is. I probably should with the stock turbos before removing them.
2013 335is - sold
2011 335d |
06-28-2021, 05:59 AM | #20 |
973
Rep 3,219
06-28-2021, 07:50 AM | #21 |
2002
Rep 3,731
From what I've seen....most stock turbo FBO cara should be running high 11's on an ethanol tune.....if you can get your tires to hook up.
06-28-2021, 08:31 AM | #22 |
973
Rep 3,219
That's good enough, the problem is Ethanol is a pain to get here, there's almost no pumps about and have to order it online, to much hassle. Will have to stick to 93 oct for the time being.
