tricks for separating rear hub from half shaft
06-16-2021, 01:12 PM | #1 |
upgrades. Upgrades, EVERYWHERE
54
Rep 60
so this is my fault and I'll save the long story, but what are your tricks for getting the half shaft (output shaft) from the hub? Mine doesn't seem to have a lot of rust in it but refuses to come out -- oh and the axle nut came off without too much effort. I have a few more days for other parts to show up, so I have time.
so far, I've tried : PB blaster on both front and back side of the spindle, about 3 gallons of it hit it with a hammer on the end just tried to hit it with an air hammer on the end So what's your tricks ?
2018 G38 M550xi
2015 F25 35i 2011 E92 335xi (m4 brakes? koni yellows? Momo's on Conti Force? ...oh what I have done) 2008 E63 ///M6 |
06-16-2021, 09:04 PM | #2 |
640
Rep 768
bolt-on hub-puller
Failing that, Jaw-puller. Failing that, Hydraulic jaw-puller. It might damage the hub.
Sometimes a bolt is just a bolt.
06-16-2021, 09:15 PM | #3 |
2124
Rep 2,758
This is what I had to use, and I live in California with no rust at all.
https://harborfreight.com/10-ton-3-j...ler-64982.html They have a smaller 5-ton one but it did not budge my axle, I returned it and then got the big one. |
06-18-2021, 02:29 PM | #4 |
54
Rep 60
in this case it isn't a problem - I just got the replacement spindle and such and its in perfect shape (heh, car only had 18k on it!)
Off to harbor freight I go!
2018 G38 M550xi
06-18-2021, 05:11 PM | #5 | |
54
Rep 60
2018 G38 M550xi
06-19-2021, 10:20 AM | #6 |
17390
Rep 18,779
Mine all but one have easily come out with a two-sledgehammer tool (one hammer on the axles shaft, the other to hit the hammer head). One out of 6 did not come out with the sledgehammer tool, well easily. I mushroomed the head of the axle. As a result I bought a bolt on hub tool. I've yet to use it, but I'd expect it will work fine.'
And buy some Kroil; best penetrating oil on the market.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
06-19-2021, 03:27 PM | #7 | |
54
Rep 60
Really dumb and I really hope the answer is "nothing" -- why are their different part numbers for the manual, DCT and automatic?? (When it comes to the rear, I'm completely surprised they're not all the same part number) |
06-19-2021, 05:05 PM | #8 | |
372
Rep 531
Drives: 2007 E70 4.8i, 2008 E90 335i
1) Use a bearing separator and separate the hub from the bearing while pulling the axel and replace the bearing. This worked but it required some sacrificial lug studs. They mushroomed badly under the force and I had to file the ends after doing it so that they didn't strip the hub. I ended up just changing the bearings and buying new hubs but the hubs aren't cheap on an M3 rear end that I am swapping in. It takes a lot more force to separate the bearing AND free the axle so it worked but wasn't ideal. 2) Get a mid range 3 jaw puller and tighten it down then hit the puller shaft with a 2lb hammer, tighten and repeat several times. If you get it centered well the combined force of the puller and shock of hitting it with the BFH will break the axle free then you can just use the puller after that. I just used this one from amazon: "DURATECH 6-Inch 3-Jaw Gear Puller, Removal Tool for Gears, Pulleys, Bearings and Flywheels" It was $23. I recommend Option #2. It just puts a small divot in the axle end where the jaw puller is centered. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
06-23-2021, 04:43 PM | #9 |
2124
Rep 2,758
