06-11-2021, 11:42 AM | #1 |
Rep 2
Exhaust Flap Controller
I spent my time looking for an exhaust flap controller but all of them were a task to install and cost over $100. Best solution is to buy a wireless OBDII adapter and Bimmerlink and you have the option to override the exhaust flap controller.
06-11-2021, 12:42 PM | #2 |
50
Rep 129
Drives: M550I xdrive
pull the fuse it's way easier what model is it
06-11-2021, 04:26 PM | #3 |
376
Rep 1,223
The ability desired here is to open/close the valve at will, regardless of drive mode.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
06-11-2021, 06:55 PM | #4 |
542
Rep 1,064
Drives: i5 M60, M5's, 535.335, M550i
BimmerLink can do it. You have to leave the Bluetooth receiver plugged into obd port, that's only downfall. But with that you can open close as you wish while driving.
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
06-12-2021, 05:13 AM | #5 |
704
Rep 803
From what I'm gathering you need to have a dongle plugged in for aftermarket exhausts like Amrytrix as well. Its too bad you can't have more than 1 device working at a time through the OBD port.
06-12-2021, 08:12 AM | #6 |
376
Rep 1,223
Yes, good option. The new Dinan solution however has a remote fob which can activate it. The remote can also be programmed to one of the programmable garage door opener buttons above rear view mirror, or other button. More money yes, cleaner install, yes.
540iSUP704.00 |
06-13-2021, 12:20 PM | #8 | |
704
Rep 803
06-13-2021, 02:28 PM | #9 | |
376
Rep 1,223
https://www.dinancars.com/products/e...arts/R660-0002
540iSUP704.00 |
06-14-2021, 09:48 AM | #10 | ||
704
Rep 803
06-18-2021, 08:23 PM | #11 |
253
Rep 298
Here's another option I came across online.
https://www.ecstuning.com/b-cg-preci...yABEgJ32PD_BwE Only $200, but still looks pretty well made. I'm still not convinced this or the Dinan are adequately weatherproofed at the connectors, but I may be overly concerned... Shouldn't there be boots over the area where the wires enter the connector to seal out dirt and moisture? (like Bosch connectors) Or is the sealing built into the connector? One observation, the installation on the one sold by ECS is a bit simpler. The Dinan requires tapping into 12vt+ and adding grounds. Where as the one sold by ECS appears to get all its power and grounds through the existing valve wiring. It also can be integrated with HomeLink like the Dinan. |
540iSUP704.00 |
