New to forum - 54C8 transfer case code - info needed
06-09-2021, 11:52 AM | #1 |
Rep 9
Hi All,
I recently purchased a 2007 335xi, just hit 100K. I have a 54C8 code that has appeared. It also seems to coincide with the symbol for brake fluid coming up as service needed (symbol in red) on my dash. This issue may also coincide with getting the orange check engine light on my dash while driving in sport mode (at about 4000-5000 rpm). From what I can see the 54C8 code is a transfer case code, possibly revealing that the fluid needs to be changed or that the transfer case clutch plate engagement might be out of spec. I'm just wondering if anyone has any insight into this. Will changing the fluid be the first step to see if that rectifies the issue? Or is this something where BMW will need to calibrate something with the transfer case. Is it advisable not to drive the car with this code? I haven't encountered the check engine light since the first occurance a few days ago. Any info/insight would be much appreciated. |
06-09-2021, 12:01 PM | #2 | |
393
Rep 972
I don't believe there is any sensors for transmission fluid replacement either. It is a good service to get done although a little expensive. You may want to have a shop view this code at the same time. are you running same size tires front and rear? Or are you a staggered set up?
Instagram : @Bimmer_bro
06-09-2021, 12:10 PM | #3 | |
Rep 9
I'm running a staggered setup on the car, you think that is somehow related? |
06-09-2021, 12:42 PM | #4 | ||
393
Rep 972
You can ONLY run a staggered set up on a xi if the front and rear tire circumference is within 1% of each other. If it is not within 1%, it will cause damage and premature wear of the transfer case clutches + excessive heat. What are your front and rear tires sizes ?
06-09-2021, 05:41 PM | #5 | |
Rep 9
I thought the tire setup on the car was factory but perhaps not? front: 225/40/18 rear: 255/35/18 I think that's within 1%. |
06-09-2021, 07:21 PM | #6 | ||
393
Rep 972
The transfer case / auto trans is one unit. The filter is actually built into the pan of the transmission/transfer case. So the whole pan gets replaced and the fluid. Some member do the sleeves and solenoids in there too. I just had a shop do the pan filter and fluid. I got 3 quotes in town and they were all around 1400. Might be different where you live. You are due if you haven't done that yet. Might be a good idea and they can scan and figure out your tcu code at the same time. Once you have your issues sorted and service done, I highly recommended stage 3 xhp. It will transform your car for the better.
06-09-2021, 07:27 PM | #7 |
393
Rep 972
When you get the check engine light at 4500, does it throw it into limp home mode? (Reduced power until the car is shut off).
06-09-2021, 08:26 PM | #8 |
Rep 9
06-09-2021, 08:27 PM | #9 | |
Rep 9
06-09-2021, 08:44 PM | #10 | ||
393
Rep 972
You have to buy the licence and then the stage map you want. It will transform your car. Do some reading on it. Just like MHD, you can flash with your phone with the apps. The MHD wireless dongle works best. I realized I just said a lot of things you are probably unfamiliar with but they are all super popular so google or YouTube it
06-09-2021, 09:03 PM | #11 |
Rep 9
06-09-2021, 09:46 PM | #12 | |
Rep 9
06-09-2021, 10:37 PM | #13 | |
393
Rep 972
Could be a misfire from a bad spark plug, coil pack. Injectors can also be troublesome on the older models. Could also be a boost leak if you're not meeting boost target. This is all just guessing. You will need to scan the ecu to see the proper code.
06-09-2021, 10:38 PM | #14 | ||
393
Rep 972
Yes exactly. Just a good preventative measure. My car shifted smoother after for sure.
06-10-2021, 07:50 AM | #15 | |
Rep 9
06-10-2021, 08:32 AM | #16 | ||
393
Rep 972
Are you getting a check engine light or a 4x4 light? These transmissions are complicated but can handle a lot if cared for properly. You may want to take it to have the transmission service done and the code checked out. Choose a shop that's familiar with BMWs
06-10-2021, 09:31 AM | #17 | |
Rep 9
06-10-2021, 06:34 PM | #18 |
78
Rep 239
This simply isn't true on these cars (or any BMW as far as I know). They are physically connected, but not one unit by any means. The transfer case has its own fluid, controller, etc.
06-10-2021, 07:21 PM | #19 | |
393
Rep 972
So guess I have serviced my transmission and both diffs. Still original transfer case fluid with no apparent issues.
06-11-2021, 09:13 AM | #20 |
298
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
Guys, transfer case is separate. It has separate fluid, and a separate controller. You can change the fluid (only takes 1qt) and you need to reset the case once you do so. It will reset it to adjust to the new fluid. I did it on mine with ISTA+.
54c8 - This code gets set commonly when the actuator clutch in the T-Case has a problem. It means that the value of resistance the actuator needs to fully engage the T-Case is different than what it actually took. The common reason is that the case has not been serviced and needs new fluid. Another cause is that the connection to the servo is corroded and the motor does not get full voltage. In your case, I would start with a fluid change, and reset. If it comes back, it's time to look for a transfer case. Good luck. |
Tags |
transfer case |
