BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    MPE tip adjustment
      05-07-2021, 08:25 PM   #1
saveywil1
231
Drives: ‘21 F90 M5 Competition
MPE tip adjustment
It’s a small thing, but I feel like the MPE tips protrude just a little too far. Anyone else feel this way?
Plus, is there a way to adjust them?
      05-10-2021, 04:32 PM   #2
Boiler Up!
Drives: 2021 M5C
If you grab a pic I can compare to mine. From directly above, I can just barely see the corner of the outer tip. I think it looks spot on.
There does seem to be some adjustment via loosening the allenhead bolt securing the clamps. It not going to be easy with the exhaust on the car, but doesn't seem impossible.
      05-11-2021, 08:17 PM   #3
Demon Barber
292
Drives: 2018 M5, 2022 911 Turbo S
I think there is room for small adjustment, but it may be really difficult to get a wrench or socket in that gap without dropping the exhaust. Maybe post some pics?
      05-12-2021, 12:20 AM   #4
saveywil1
231
Thanks for the replies. I will get some pictures taken for comparison.
      05-15-2021, 02:01 PM   #5
saveywil1
231
*Updated with pictures*
      05-15-2021, 07:54 PM   #6
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Based on the pictures, especially the first, it does seem to me that it does protrude quite a bit past the bumper line.
I had the same issue when I had my iPE exhaust installed and was able to easily make adjustments as the bolt for the clamp was on the lower end of the pipe which made it easily accesible.
I guess my question is .. can you loosen the bolt on the clamps enough to rotate the clamp to where the bolts are on the bottom? This may be an easy way to make the adjustment without having to drop the exhaust.
The tips are big enough that the bolts will not be visible any way (at least I don't think so).
Good luck! Let us know how it goes.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      05-15-2021, 09:10 PM   #7
Boiler Up!
Drives: 2021 M5C
Looks like your tips are extended pretty far out. Here’s what mine look like. You can see clearly from below that mine are nearly fully seated inward.
      05-16-2021, 05:32 AM   #8
saveywil1
231
This looks way more encouraging. With mine, I feel they look like fake tips from Auto Zone...
Now the problem is I am very non mechanically capable, is this something I can manage on my own with minimal tools?
      05-16-2021, 06:40 AM   #9
Boiler Up!
Drives: 2021 M5C
My assessment is that the rear section of the exhaust will need to be dropped in order to loosen the 5mm allen-head bolts that secure the tips. I can get a wrench on the bolt head, but there is zero clearance for movement even with a mini ratchet. I would take it up with your dealer.
saveywil1230.50
      05-17-2021, 02:19 PM   #10
saveywil1
231
That is wildly outside my skill set. Dealer it will be! Thanks for the information.
      05-18-2021, 07:53 PM   #11
The5rivers
314
Drives: 21 M5C, 22 X3MC, 24 X7 40i
saveywil1 just curious but did you notice this when you picked up the car in SC, or after you got home? I would have probably said something right then and there!
      05-18-2021, 08:46 PM   #12
saveywil1
231
I did, honestly I wasn’t sure if that was how it was intended to be. Very relieved that it is not!
      05-18-2021, 08:48 PM   #13
The5rivers
314
Let us know how the fix goes!
saveywil1230.50
      05-19-2021, 01:31 AM   #14
MOHCTP
Sergey UA
Drives: 2010 BMW e90 M3
If you remove rear diffuser , whole black cover not just center piece, easy to do some bolts and clips ,you shoud have alot of space to acces exhaust tips clamps , easier than dropping whole exhaust system IMHO
saveywil1230.50
