| 05-02-2021, 01:40 PM | #1 |
![]() 88
Rep 91
F90 M5 Competition Track Guide & Tips
![]() Featured on BIMMERPOST.com Summary - a 2021 F90 M5 Competition LCI can 100% handle a solid day of track as standard without breaking a sweat. But to make it interesting, a bit more detail: The car is heavy but the setup is perfect so it will not feel uncomfortably heavy on track. You can chuck it around with minimal understeer and have a great time. The suspension could be lower, and I'm going to give the M Performance setup a go with a 20mm drop, but it's certainly fine as stock. The stock steel braking setup - discs, pads, fluid - didn't break a sweat. Pedal feel was great all day. No need to upgrade for performance reasons. I may try out track pads and put a higher temp fluid in, but there was no reason to suggest that's actually necessary. Mine came with the Pirellis from the factory, and I wanted to get solid lap times, so the only change I made was that I put Michelin Cup 2 Connects on - the newer Connects come in the exact standard 20 inch tyre sizes for both front and rear, unlike the previous ones, so there was no need to run a non-standard setup. With the tyres adjusted for the right pressures, they were rock solid for the whole day, and the car was faster on track than anything else there - all the other M cars (including new gen M3s and M4s, an M5 with the PS4Ss, and a few M2 Comps), and a 570S (on standard Pirelli P-Zeros). For tyres, the Michelin Connect app is excellent as it helps you tweak starting pressures to make sure you maximise the time within the optimal range. I found that I was starting on around 26 psi in order to run between 32 and 35 once warmed up for a good 15-20 minutes before they would then go over that pressure and you can start to feel the car sliding around a bit too much (not in a fun way). Steering is definitely best in Comfort so you can play around with it a bit easier and slide around - the feel is not better in Sport so it's just a bit heavier and harder to quickly rotate when you need to put some lock on. Engine and Drivetrain definitely Sport Plus. Optimal driving mode is 4WD DSC Off if you want the ultimate lap time of 4WD Sport DSC Off if you want a more engaging driving experience. MDM cuts in far too aggressively - it's not smooth like the supercar electronics these days, it just cuts you off once it starts to slide, and that makes it hard to balance the car and keep the pace up. With Cup 2s, and 4WD, there was never a time that the car lost traction unless I specifically chucked it in to achieve that. Hold down DSC Off for 10 seconds, tweak the engine and drivetrain settings, then hold down M Mode for 10 seconds and set it into Track to switch off all the various electronics and entertainment, and you're set. So basically if you have an M5 and want to take it on track, then you're totally good to go. No changes needed. If you absolutely want to set the best lap times on the day, then just stick some Cup 2s on it. The rest of the car is absolutely built for it. Hope this is interesting and helpful to people! |
30
Simon H983.50 pmatias03115.00 POBA340.50 limeypride4473.00 FourPtDrift273.50 Alberta2213.00 ashmostro1393.50 Jamesmick133.50 TXM3CX112.50 unfoundnemo1977.00 Herofmine1039.00 sbilyayev102.50 swagon13462.50 eman45172445.50 imperfectluck674.00 brava09834.50 JSal335is144.00 Kevin_The_Clean15736.00 flanast146.50 ando2388.00 Powerslide1137.00 kebiN21.00 dazzapb1079.50 CERF04ZHP7.00 ///MRazv2113.50 Thewolfbmw257.50 clee1982799.00 theserbatron36.00 Rams016.00 M5 London483.50 |
| 05-02-2021, 02:10 PM | #3 |
115
Rep 293
Drives: 2021 M5 Comp, 2011 M3 E93
Solid review! Thanks for sharing.
| 05-02-2021, 03:30 PM | #4 |
Both Feet In
508
Rep 264
Drives: 2011 SG DINAN E93 M3
A lap around Road Atlanta two years ago in an M5C with Matt Mullins at the wheel is why I’m taking delivery of a new M5C is just over three weeks. The car was a beast on track, can’t wait to take my down to do a track day soon.
| 05-03-2021, 07:23 PM | #6 |
![]() 1438
Rep 1,195
Great to see there’s no limp mode, overheating, brake issues, etc. on the stock setup. This proves it’s engineered quite well and will handle most everything you throw at it on the street.
unfoundnemo1977.00 eman45172445.50 |
| 05-05-2021, 02:17 PM | #7 |
350
Rep 280
May I ask what your prior track experience is? Are you a beginner/intermediate/advanced level driver?
I find it quite surprising that the much heavier M5 can take a full day of beating with everything stock without even an eventual brake fade.
[SOLD] 2020 ///M4 CS
| 05-05-2021, 02:19 PM | #8 |
Rep 9
Nice review, though I would say it isn't advisable to take BMW OEM brake fluid to a track day. Yes, it holds up fine as long as you can manage the temperatures and drive a cool down lap. But you'll regret it the first time a red flag comes out on a brake intensive circuit and you end up having to stop on track after a heavy braking event. My advice: You already forked the money over for a new M car; even the most expensive brake fluid is only $70 and the dealership will even flush your brake system with it if you ask them to. Cheap insurance to keep you going and peace of mind that you won't boil your fluid.
unfoundnemo1977.00 |
| 05-05-2021, 03:28 PM | #9 | |
![]() 1977
Rep 2,039
Drives: 2026 i5 xDrive 40
Current: 2026 i5 | 2025 iX
Gone: 2022 G26 i4 | 2022 G07 X7 | 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
| 05-05-2021, 06:12 PM | #10 |
381
Rep 602
I have the same experience as RS61 on the track with my 2019 M5 Comp, stock and steel brakes.
2 seasons so far (about 16 track days), starting the new season on May 10th. Everybody cannot believe how good the stock steel brakes and pads are (pads are made by Pagid for BMW). I even shared my car with a friend on a track day so it did double duty, no fade whatsoever.
2019 - M5 Competition
| 05-05-2021, 07:15 PM | #11 |
![]() 835
Rep 1,709
Love it, thanks for sharing it!
I don't really feel the MDM cutting off at all, is it possible that pre LCI cars MDM are tuned differently?
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
| 05-05-2021, 09:29 PM | #13 |
376
Rep 1,269
i tracked my f90 comp on ccb's several times last year with toyo r888r's.
the car was def one of the fastest. although not as fun on the turns, the f90 was badass and insanely impressive on track. albeit its a different feeling ripping thru a track course in a heavy sedan, than a ~3400lb or less coupe, but fun nonetheless the reason i bought the car was after my 2 day bmw track event @ thermal with the m5's. i feel in love enjoy the season! try the triple 8's or full slicks itll be a riot
| 05-05-2021, 09:43 PM | #14 | |
![]() 1176
Rep 2,028
| 05-05-2021, 09:55 PM | #15 |
555
Rep 386
I think there is no doubt any M5 can handle a track day, but tires on the other hand are another story.
I corded a pair of Pilot Sport 4s on my last weekend at NJMP - T. The car is a beast but it's a tad heavy and hard on its tires.
2014 F10 M5 - Space Grey on Sahkir Orange
2016 F48 X1 - Black on Black 2017 F87 M2 - LBB on Black |
| 05-05-2021, 10:58 PM | #16 | |
381
Rep 602
| 05-05-2021, 11:00 PM | #17 | |
381
Rep 602
I went though 1 set of Pirellis and will soon need to replace the Nittos as well…
| 05-05-2021, 11:36 PM | #18 | ||
555
Rep 386
I will have to experiment with some better pads and tires. Admittedly I enjoy using the M2 at HPDEs a little more. Have you had a chance to find the tire sweet spot (in regards to tire brand/model).
| 05-06-2021, 06:58 AM | #19 | |
1137
Rep 2,286
I know the App says you should start the session at recommended pressures - warm up the tires and then pull into the pits and bleed back down to ideal - but obviously you lose valuable time in your 25-30 minute session - so I started doing the same as you - start a little below recommended pressure and then hope to not have to pull over before tires start getting greasy. Since I only did one session without pulling over to bleed the pressures back down - approximately how many minutes did it take for you to start getting into the 35psi range or notice the tires starting to get greasy? |
| 05-06-2021, 07:30 AM | #20 |
461
Rep 1,281
IÂ’ve driven the M5 comp, M2 comp, m3 comp, m4 comp, and finally the m8 all on the circuit of AmericaÂ’s. What makes a good track car and a good daily driver is somewhat at odds.
the M5 is a great luxury/performance sedan that acquits itself well on the track. I would choose an m2 comp as an actual track car as itÂ’s a performance/luxury car (in that order). The m2 is a better teaching/learning tool. Without awd the m2forces you to be smoother, and more careful in throttle application especially out of turns where the M5 and m8 are more forgiving of too much throttle (but your going slower). The M5 is so smooth and forgiving (luxury) that itÂ’s easy to not notice as quickly that your over applying throttle while exiting the corner and now your slightly under steering. It also takes a lot of initial braking to settle that heavy front end in sweepers. Where as the m2 comp you know exactly when you applied to much throttle, the feed back is mucH more immediate and obvious. So IÂ’m comparing the 2 cars because for track purposes I want my m5 to be more like the m2. I would evolve the m5 to have the characteristic I like in the m2. The mods I believe the M5 needs are as follows for better tracking. Weight loss, better tires, clear bra or similar to protect your paint, fire extinguisher mount, and a 6 point harness seat and your ready for most competition. Lowering is not necessary, carbon ceramics are not necessary (cast iron is cheaper when your rotors need replacement from warping). Heat doesnÂ’t seem to be an issue, IÂ’ve driven it under race conditions in 95 degree heat. The interior mods will compromise the car for daily use. So IÂ’m in the camp, a daily is not a track car. Better to have a dedicated track car and a daily as the environments are radically different. With the super low speed limits, traffic, bad pavement and gentle corners you never even come close to the limits of a modern vehicle. I do run races in my 2016 550i xdrive. I do miss the hydraulic steering in the old bmws... I like open road races vs track days, which is a different kind of driving (less braking) |
| 05-06-2021, 05:42 PM | #21 | |
381
Rep 602
The OEM Pirellis were fun and also comfortable on the road but I went through them in no time. Now, the Nittos, I'm not sure still. The car behaves very differently and is much more twitchy in the hard braking zones (Mainly after the long straight of my track - 240 kph to 110 kph). For sure I'm not fully exploiting the Nittos. These street legal Nittos are not comfortable on the public roads ![]() I was able to fit a 305 in the rear with the Nitto, fits barely, no rubbing. Next I will try either the Michelin PS4 or Cup2
LBBF87554.50 |
| 05-07-2021, 09:13 PM | #22 |
![]() 2272
Rep 1,694
Having tracked my 2018 M5 extensively, there are some tips and tricks I agree and disagree with above.
Details: 1. When pushed REAL hard, DSC fully off will put you backwards and sideways QUICK unless you are a real expert. I've been doing this 20 years and I'm no expert at 600 hp tiptoeing around really tight turns with a 4800 pound car. Being backwards in the grass in turn 3 at VIR while pursing a pretty fast 911 reminded me of the benefits of M dynamic mode. 2. The rear pads, OEM, are garbage especially with M dynamic mode. I can't remember how many sets of rear pads I've now replaced. And getting the right tool to do so was a long search to make sure I didn't do something stupid. Make sure you get the right MECHANICAL tool, and if you're a whiz at electronic stuff go for trying to find the right tool to do it. None of the OBDII tools I could buy affordably can retract the motors. I'm told it can be done other ways, but the mechanical is the SUREFIRE way to do it without damage. 3. The brake cooling in the front WORKS WELL. The OEM pads will last well. I have now used several pads from RacingBrake, the only track capable pads available in the U.S., and they are better than stock. The European pads from BMW can be imported, for about $700 for fronts. A lot. The brake fade compensation in the car makes the brakes seem much, much better than they really are. Long term track goers will notice the pedal moving around. It's kinda weird. 4. The Pilot 4S's are decent. The Sport Cup 2's are better. Toyo R888R's are much better, but holy mother of pearl the noise. Randy Pobst came to my garage to tell me that one of my diffs had to be failing it was so bad. Best tires I've run so far - Toyo Proxes RR's. Durability and traction blow the Sport Cup 2's out of the water. 5. The M2 is stated above as a better track car. If you have a handling only track - maybe. If you're on a power track....well. If you don't mind being passed by a bargain basement Corvette go for it. I have a 2018 M2 that I have tracked same day as my M5. The M5 does MUCH MUCH better on power tracks. My experience at VIR vs. M2's on track is roughly a murder scene. I can keep with them fairly well in the twisties, and they become a hood ornament on the straigtaways. I'll take the M5 sir. 6. Finding adequate restraints for frequent track use has been a shit experience. The sport seats in the M5 CS will make this much easier, but 4 points may be the best we can do. This beast can turn a corner much faster than the OEM restraints can handle. We need proper seats with passthroughs. The stupid Supra has proper passthroughs in the OEM seats. What was BMW thinking without offering some sort of sport seat? The M3 and M4 optional seats looks proper for this, and the ones in the M5 CS look like the same. We'll see 7. Do replace the brake fluid. Castrol SRF is the best. I've used it and Endless. The fade compensation comes in the least with the SRF. 8. Be prepared for front end and windshield damage - tire worm and bug impacts at 150mph can crack the windshield and dent the hood pretty well. This beast can generate those speeds pretty handily. You wanna keep it in pristine shape? Not the sport for you. Shawn |
11
FatRear081437.50 Neptune71528.00 MysticBlue372.00 Jamesmick133.50 stealth70mde381.00 luke1990160.00 Rams016.00 imperfectluck674.00 TheCookieMonster327.00 M5 London483.50 Autoregression116.50 |
| Bookmarks |
