04-29-2021, 02:10 PM | #1 |
63
Rep 41
Jerky acceleration from standstill in sport+
So I picked up my car from BMW the other day. Stopped at a light, and as the light turned green I pushed the throttle down about halfway in sport+ mode with the DCT in "3" (not 3rd gear, but the fastest setting) and the car did this weird, very unpleasant bucking motion instead of accelerating smoothly.
Has anyone else experienced this? Is it related to the throttle response in sport+ or the DCT in "3"? Edit: added clarification that I'm not trying to start the car from 3rd gear Last edited by goobus; 04-29-2021 at 05:26 PM.. |
04-29-2021, 02:45 PM | #3 | |
493
Rep 492
The DCT is an automated manual, when you started in 3rd in the most aggressive throttle setting, and it's trying to let the clutches out to get you moving. The trans is not going to stall out, but it's going to not be happy being bogged down like that. If you started a 6spd manual car in 3rd and nailed the throttle a bit on a sensitive setting, it's going to react the same way. |
04-29-2021, 03:17 PM | #5 |
63
Rep 41
04-29-2021, 03:26 PM | #6 |
651
Rep 504
Yeah you have to feather it a bit and then nail it. That's my experience. I'm not able to leave by flooring it anyway...it just lights up the tires and gets all squirrely.
04-29-2021, 05:20 PM | #7 | |
1090
Rep 2,799
2021 M2C HS/6MT/Exec/Moonroof
04-29-2021, 05:53 PM | #8 |
5531
Rep 2,291
Skip to the 3:28 mark for your answers
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
04-30-2021, 12:42 AM | #10 |
5865
Rep 6,635
Yeah, this is normal. You have to figure out how to drive it. I'm used to it now. I find I need to be deliberate with the throttle. You don't want to confuse it and ride the clutch. If it does start bucking just take your foot off throttle until it stops then try again. I find it's most likely to happen to me when going up a hill in first gear. Instead of slowly rolling onto onto throttle I just go right to like 25% throttle so the car isn't confused with what I want.
04-30-2021, 02:54 AM | #12 |
74
Rep 123
Sounds like it could be driver induced throttle oscillation. When you first apply the accelerator pedal, the car starts moving forward initially, causing your foot to lift a little bit off the accelerator pedal. Then, as your foot lifts off the accelerator, the car slows down, causing your foot to crash back into the accelerator pedal and press into it harder. Then the cycle repeats itself and results in the bucking motion you describe. It’s most prone to happen when you have the most aggressive throttle mapping (sensitive accelerator pedal), the most aggressive DCT setting (resulting in the most aggressive initial forward motion to get the cycle started), and you apply partial throttle in an aggressive manner. You can avoid this by using less aggressive throttle/DCT settings, being smoother on the initial accelerator application, letting off the accelerator when it starts to buck, or burying your foot in the throttle so that your foot doesn’t come off the accelerator pedal when the car starts to buck (and thus stops the cycle from repeating).
04-30-2021, 08:10 AM | #13 |
6525
Rep 3,072
Drives: M2 CS, 18 Vantage AMR, 00 WRX
Why are you in sport+ and shift level 3 at a set of lights? Do you use starting blocks to be first to the checkout at your supermarket? It makes the same amount of sense.
04-30-2021, 08:27 AM | #14 | |
3904
Rep 4,048
Drives: 2020 M2C, 2019 330xi, 2017 Q7
My car will lurch even in S mode |
04-30-2021, 10:41 AM | #15 |
2865
Rep 3,842
The 6MT manual will "buck" as well. I wonder if cars with coilovers have the same problem. It could be a traction control issue also. Anyone have this happen with DSC off?
JustDrifting232.00 |
04-30-2021, 04:06 PM | #16 |
63
Rep 41
Sounds like I just need to spend a bit more time with the car. It was hilarious cause I had a truck behind me and he backed way off when he saw me bucking like that..probably a smart move considering I don't really know how to drive this beast yet. Will probably stay in sport mode and transmission level 2 for now.
04-30-2021, 06:17 PM | #17 | |
493
Rep 492
04-30-2021, 10:34 PM | #18 |
5865
Rep 6,635
It's not about racing a Prius from stoplight to stoplight, the settings change the character of the car, the way it feels. The lowest shift setting slips the clutch for smooth shifts. The highest snaps them off quick and rev matched down shifts.
Davil6524.50 |
05-14-2021, 03:36 PM | #20 | |
232
Rep 73
Lurches slightly, even if under constant light throttle. Doesn't matter if in efficient, sport or sport+. Doesn't do it if mashing the throttle/driving hard, just gentle constant throttle.... |
12-08-2021, 08:51 PM | #21 | |
Rep 8
12-08-2021, 11:13 PM | #22 |
2050
Rep 1,200
My tuner Ian@Bend Calibration sorted the jerky throttle. Can daily drive around in S+ all day without any jerk/buck non-sense.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
