Bimmerpost
4 Series
Technical Topics Wheels and Tires Wider Tire Recommendation for M440i
      04-22-2021, 03:48 AM   #1
Weishaa
Drives: BMW G22 M440i
Novice here. I have square 19x8 OEM 791m wheels with 225/40 RFT all season tires on my G22 M440i. I am thinking to upgrade to 235/40R19 or 245/40R19 for better grip and handling. Since m440 is awd, I think square is good.
I saw some discussions on m340 but haven't seen any for m440. I know 245 is the max size recommended for 8'' wheel but it doesn't guarantee the spring space. So I want to confirm if 235/40R19 or 245/40R19 works well for m440 without rubbing or deflection. I want to avoid spacers for now.
I will go to track days so I don't want any issue because of the wider tires. If 245 fits well, will it decline the handling by any chance? Will the height be a problem if I keep using the stock suspension?
I am going to RE71R but open to any suggestions for other extreme performance summer tires. I know ps4s is the golden standard here but multiple friends on track think that ps4s "compromise" too much on comfortable.
Current 2021 G22 M440i
Pervious 2010 F07 535GT
      04-22-2021, 02:00 PM   #2
cywing1119
100
Drives: 2010 E92 M3
i'm running 255/35/19 on my front and lowered my car, haven't rub at once even on track, so you will be fine with that, when you switch to wider tires, the immediately feeling is your steering wheel feel heavier while turning, and for sure better grip give you more confident
      04-22-2021, 02:11 PM   #3
Weishaa
cywing1119 Wow, I thought the Max. tire width for an 8'' wheel is 245. You really can use a 255/35 tire on an 8'' wheel? without spacers? Any rubbing when full lock and reverse?
Do you mind posting some pics of your setup?
btw, what tire do you use?
      04-22-2021, 03:33 PM   #4
cywing1119
100
Drives: 2010 E92 M3
not on stock wheels for sure lol, and i'm running PSS tires
my wheel spec is kind of wild, 19x9.5 +23 on front and 19x10.5 +34 on rear, no spacer, haven't experience any rubbing in any case with dinan lowering spring
      04-22-2021, 03:49 PM   #5
Weishaa
I see. Awesome setup! I will live with the stock wheel and spring for now, so 235 probably is the safer choice as the 1st step. minimal speedo and height changes
Do you change the brake? Some suggested upgrading brake line and fluid should be a good start.
      04-22-2021, 03:56 PM   #6
cywing1119
100
Drives: 2010 E92 M3
i upgraded my brakepad to endless mx72+ for track use, but still on stock brakes line and fluid, will change those as well, for daily use the stock one is fine, but if you plan on tracking it, brakes and tires are first priority to do
      04-22-2021, 05:10 PM   #7
Weishaa
Thank you, sir. Safety is always the 1st priority.
Do you feel fading when the brake is cold? if so, how bad is it? will it affect your daily drive on highway?
      04-22-2021, 06:33 PM   #8
LaVitaEBella
72
Drives: 2016 BMW M3
How are you dealing with the rubbing issue?
I like the red accent of those black wheels. Did you paint it? It reminds me of the KMC wheels District model because of the design.
      04-22-2021, 08:07 PM   #9
cywing1119
100
Drives: 2010 E92 M3
not really, just some brake squeeze noise when the brake is cold sometimes, but not noticeable stopping power difference
      05-27-2021, 03:01 AM   #10
rmtdewz
Drives: 08 E90 M3 6MT
What size rear tires are you running on your 10.5 wheels?
Tags
g22, m440, tire, wheel, wheel and tire, wide
g20
