Flushing coolant with electric waterpump?
04-16-2021, 02:57 PM | #1 |
9
Rep 130
What is the best way to do a complete coolant flush? I have G13 red coolant currently but want to change it to BMW blue and I know it's bad to mix them, so will probably need to do a flush with clean water a couple of times, but still, what is the best way?
04-16-2021, 04:08 PM | #2 |
528
Rep 1,165
Drives: 09 E92 335i 6MT
Here's what I did when I discovered there was green coolant in my car.
Jacked it up, removed intercooler, then drain the radiator, then I pulled the hose connecting the water pump and thermostat to let that drain. Connected that hose back to the water pump and thermostat, filled the system with distilled water, ran the bleed procedure and then repeated everything until I only saw clear water come out. You could probably do this with just draining the radiator everytime but with how much dumps when removing the wp/t-stat hose I figured adding that would be faster. There's probably a better way but this works for me lol
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
04-17-2021, 09:04 AM | #3 | |
2442
Rep 4,330
Don't run the pump dry or you will damage it. |
Mosaud19983979.00 |
