04-11-2021, 12:11 PM | #1 |
61
Rep 63
Jb4 CEL with catless DP
I installed a mini cat from turner Motorsport on the secondary o2 in order to eliminate the CEL. Now I'm getting a new series of codes. I initially thought that the jb4 eliminated the CEL when installed. I'm running map 2. Looking for options to fix this. Is it possible that the sensor is too far out of the exhaust stream now? Or can this be fixed with tuning?
Thanks! |
04-11-2021, 05:18 PM | #3 |
61
Rep 63
04-12-2021, 08:45 AM | #4 | |
Joint Chiefs of Staff
24238
Rep 190,879
MLJR235116.50 |
04-12-2021, 07:53 PM | #5 | ||
61
Rep 63
04-13-2021, 02:38 PM | #8 |
111
Rep 342
The afr is based on the upstream o2. It's the downstream o2 that monitors catalyst efficiency that sets the cat codes. The spacer goes on the downstream just like he has it. I think the issue is the car is smarter than the old school jb4
04-13-2021, 02:39 PM | #9 |
111
Rep 342
Just a thought... Are the sensors plugged into the right connectors? Is it possible they got switched?
The more I look at the codes the more I think they got switched |
04-14-2021, 11:16 AM | #10 |
117
Rep 243
All "newer" updated JB4 software made it so it could no longer auto suppress the CEL from catless setups. As said before, US customers do not have that option available.
You guys should read up on JB4's and stuff on n54tech forum. That place is like the holy grail of all JB4 info you could ever want. current ECU tunes/tuners (MDH/BM3) do not suffer from this issue as this is coded into the tune and no cel's are illuminated. This does not mean your car will pass smog or anything of that nature, only it will not trigger the light on a constant basis.
'15 235i - Moddedededed
07-16-2023, 02:01 PM | #11 |
Rep 11
Sorry to dig in this old post. I ordered my ER catless downpipe and it should get here soon. I don’t live in the states but I do have a Jb4 installed on my car. Does that mean I can auto suppress my eventual CEL using jb4?
