04-06-2021, 03:39 PM | #1 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
Steering Wheel Button Fuse
Guys I need help with finding steering wheel buttons fuse. I was swapping my steering wheel shift light led, power and ground touched and blew the fuse. So except volume no other button works on steering wheel including m1 and m2. If some can pinpoint exact fuse and location will be greatly appreciated. Im thinking it's one if he fuses in passenger wheel well but Donno if fuse box or bdc. Thanks
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
04-06-2021, 06:35 PM | #2 |
105
Rep 142
Damn you sent me down a rabbit hole. I found out there are 8 steering fuses. F1,f10,f56,f57,f83,f93,f223, and f276. If you can't find a fuse card apparently bmw is making them all web-based now bmw.com/fusecard. Summary of numbers and location follow but I suggest looking up the card. 1-14 are on the bdc, 20-95 are in front right, >200 is in the back. If absolutely nothing on the wheel works I'd assume 1 or 10 the rest probably deal with actual steering. Couldn't find any doc with descriptions so my attempt at help ends here. Good luck.
04-06-2021, 06:57 PM | #3 | |
1105
Rep 1,607
GT
04-06-2021, 07:28 PM | #4 |
105
Rep 142
In that case looks like 46,63,90,91,92,204,210,252,257 or 262. Good gracious there are a ton of fuses they need to come with the kind that indicate when they're blown haha may as well check them all can't be but 3 left.
04-06-2021, 07:52 PM | #5 |
1105
Rep 1,607
So it was a 10amp far right corner of the front fuse box. I just removed every fuse till I found the bad one.
GT
04-07-2021, 02:29 AM | #6 |
1105
Rep 1,607
Thanks for looking bud.
GT
josec704099.50 |
01-02-2024, 03:08 PM | #7 |
113
Rep 219
This just saved me hours of troubleshooting. I did the same thing. I shorted the 2 pin power plug when removing connections from the clock spring and killed this fuse.
