Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > ET47 offset on 8" wheels for 328 xDrive
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      04-06-2021, 02:31 PM   #1
djy5005
Drives: 2010 328i xDrive
This puts the wheel slightly closer to the brakes. I've been running 8Jx17 ET40 wheels for a while and they're fine, but am in need of new rims as the ones I have are beyond repair.
I found a set of 8Jx17 ET47 (E46 wheels) for a good deal, but I won't lie that I'm a little concerned about the 7mm shift inward. does anyone have any experience if thesewill work right out of the box without hitting the calipers, or do I absolutely need spacers? Not a big deal if I do, but I want to just have them ready right away instead of waiting for them to ship. (also, any recommendations for a 10mm spacer? Previous threads seem to be sparse in details)
I did search, but didn't find any clear information what the absolute limits are for various wheel sizes.
      04-06-2021, 02:41 PM   #2
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
Stock fronts is 8" w/ 34 offset so you're already 6mm in from stock; those wheels are 13mm farther inwards.
I currently run a 9" wide w/35 offset in the front. the inside of the wheel seems to be at teh SAME spot as 8" 47 offset would be.
So will it work? yes. Will it look terrible? also yes.
I'm also a 335 so I have bigger brakes in the front so you'll have clearance there. But the wheels are 19" I'm wondering if 17" would get too close to the thrust arm/control arm when its that high of an offset?
      04-06-2021, 03:04 PM   #3
djy5005
Good to know about the brakes. It at least gives me hope I can get it out of the shop.
I actually didn't think about the thrust arm until now, but thinking about it with the ET40 tires, there was never a concern about rubbing there. There was definitely more than 1/4" of space around the arm at any given time since it sticks out almost directly inward before it curves into the subframe.
That said, your comment about it looking terrible might be absolutely true, so I'm probably just going to get some spacers in the near future. Just wanted to make sure I can drive it off before I scratch up anything.
      04-09-2021, 08:13 AM   #4
edycol
1509
Drives: 2011 328i xDrive
Not sure. I tried a few days ago some beater wheels 18x8 ET43 on my 328 xDrive, and it does not fit.
      04-09-2021, 08:22 AM   #5
neilvan
neilvan's Avatar
858
That's interesting! wonder why? I also had 18x8+43 (E60 x-drive) wheels on my rwd 335 to drive it to storage and had no issues.
What was the reasoning they wouldn't work?
      04-11-2021, 09:14 AM   #6
nsjames
2442
Drives: 08 328xi Touring
I run e46 47 offset 8" wide wheels in the front.
just get a 12.5-15mm spacer.
fixed.
this is 12.5 in the front.
Tags
offset, spacer, wheel
