M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2C Stage 2 - 1/4 mile and trap speed
      04-05-2021, 07:41 PM   #1
McLaren720s
McLaren720s's Avatar
Drives: 2024 M4 Competition X
I'm looking for info on what a Stage 2 M2C (tune and downpipes) runs and traps in the 1/4 mile.
I did a single 1/4 mile run using draggy at an airstrip (non-prepped surface) and clocked 11.97 @ 119mph with a 2.01 60ft and a DA of 1528. Used Launch Control @ 2500rpm
0-60 mph came in at 3.76 with 1ft rollout.
Was really expecting better numbers and especially higher trap speed around maybe 122-124mph. Disappointing
Anyone else have numbers to share?
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
      04-05-2021, 10:56 PM   #2
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2022 R8 Quattro Spyder  [0.00]
2023 X5M50  [0.00]
2023 718 Spyder  [0.00]
2024 Silverado  [0.00]
2024 Civic Type R  [0.00]
Well a 2.01 60ft is terrible and will kill your 1/4 time. That’s a lot of wheel spin.
Drive it correctly for a 1.65 60ft and your 1/4 mile will be 11.35
      04-05-2021, 11:07 PM   #3
McLaren720s
Originally Posted by Higgs Boson View Post
Well a 2.01 60ft is terrible and will kill your 1/4 time. That's a lot of wheel spin.
Well, not much to drive "correctly". It's Launch Control. You release the brake and keep the throttle floored. Nothing really the driver can do.
Maybe a prepared drag strip would provide better traction and improve the 60ft
      04-06-2021, 05:54 AM   #4
AmooManiak
637
Drives: 21 X5 M50i -> M2C -> 21 M5C
60 ft time has no baring on trap speed for RWD cars. If anything, bad launches usually result in slower ETs but better trap speeds. Better launches = better ETs and lower trap speeds.
      04-06-2021, 06:09 AM   #5
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
I suspect a dynojet on STD smoothing was involved in setting the level of expectation here.
      04-06-2021, 07:37 AM   #6
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2023 X5M50  [0.00]
Turn off launch control and drive the car.
Never said anything about trap speed. I said ET. Also, a bad enough 60ft will lower trap speed also. What you are referring to is simply a small amount of wheel spin allowing rpms to be a bit higher earlier in the run helping mph.
A 2.01 60ft is on the extremely slow end of the range. My NHRA Super Stock car 60fts 1.3 and runs 9.7 with 580 hp. 2.01 is filled with wheel spin or very intrusive power limitation on any car.
      04-06-2021, 11:23 AM   #7
AmooManiak
637
I'm not saying it's not a bad 60 ft time, but in his original post he was more concerned about ET, which has not a huge impact on the 60 ft time and the real measure of a car's power.
I do agree that I'd expect at least 125 MPH trap speed out of a Stage 2, with or without a bad launch.
      04-06-2021, 11:52 AM   #8
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2023 X5M50  [0.00]
ET is most affected by 60ft time than anything else.
      04-06-2021, 07:02 PM   #9
Karmic Man
Karmic Man's Avatar
Australia
1996
Drives: M2C
What tyres, size and pressure were u using?
      04-06-2021, 07:19 PM   #10
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
Let some air out of the tires
      04-06-2021, 09:19 PM   #11
McLaren720s
Pilot Sport 4S - 275/30 front and 295/30 rear
Tire pressure 35
      04-07-2021, 12:31 AM   #12
Karmic Man
Karmic Man's Avatar
Australia
1996
Drives: M2C
4S’s dry grip is average, S007A has better dry grip when new. 35 psi is too high for drag, 295 not wide enough for drag at your power level
I would go 305 R888R or at least the S007A if you want a tyre that is usable in pouring rain
Then from there drop the tyre pressure to 25psi to start with and then experiment it further
You will have good results with the above setup
      04-07-2021, 12:45 AM   #13
Karmic Man
Karmic Man's Avatar
Australia
1996
Drives: M2C
Falken RT660 also has the 275/305 30 set so you may also want to consider sizing up to that tyre
      04-07-2021, 01:46 AM   #14
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
Aren't you all missing the point? The OP's sig says he has 524whp, so close to 600hp crank, nearly 200 more than stock. It wouldn't matter if he had concrete rings as tyres, it should still trap well over 120mph.
      04-07-2021, 11:21 AM   #15
AmooManiak
637
Exactly my point. Too much emphasis is being put on the 60 ft and ET and not enough on the trap speed. He should be trapping at least 125 mph regardless of how bad his launch is, unless he totally bogs down.
      04-07-2021, 01:17 PM   #16
McLaren720s
I felt like the LC did pretty solid outside of the fact that there was a huge delay after releasing the brake pedal.
I would like to reiterate that this was a single run, in the "real world", not a drag strip, using draggy in an area where the signal was cutting in and out so maybe it wasn't super accurate? Not sure.
Still, I'm surprised nobody else here has some actual numbers to compare to.
I would have thought that my trap speed would be around 124-125mph so maybe the dyno read high and not really making 520whp?! I believe uncorrected number was 490whp
I think the stock M2C traps around 114mph
      04-07-2021, 01:44 PM   #17
AmooManiak
637
You are right, they trap 116 or above. Making that extra power you should see around 125.
      04-07-2021, 04:53 PM   #18
Higgs Boson
In the Details
1810
Drives: Yes
2020 AMG GTR  [0.00]
2023 X5M50  [0.00]
maybe if you could just humor us? set your rear pressure to 28, front to 40
turn off launch control and traction control etc, do a 5 second burnout out of the water (pull around the water if you can and back into the wet area but not the puddle so you don't get your front tires wet and drag water up to the starting line)
get the feel for what RPM to launch at and what rate to feed in the throttle, which could take several runs
try to get the 60ft down to 1.6 and see what your MPH comes up to without the nannies
you might be surprised how far down the track you actually get with the nannies enabled before they let the car have the full power
      04-07-2021, 06:09 PM   #19
McLaren720s
I am going to the drag strip as soon as the weather is clear here and I'll report back.
      04-08-2021, 03:29 PM   #20
ptper
589
Drives: '18 Avus Blue F80
As many have said, the 60 foot could be better. What does everybody think of the DA? OP said it was run once, so i'm not thinking a heat soak or pulled timing issue. Do you mind sharing which tune?
      04-08-2021, 06:19 PM   #21
McLaren720s
It's a Stage 2 tune from a local shop. It made comparable power on the dyno as another friend with BM3 Stage 2.
Heat soak shouldn't have been an issue because I wasn't driving the car hard before that
      04-08-2021, 06:31 PM   #22
ptper
589
Thanks. I never put any credence to dyno numbers as opposed to real world data. Good on you for doing a pull. That trap is concerning though. Getting out out to the drag strip, especially a prepped track, should let you know better where you're at. Good luck!
m2
