10-25-2008, 06:13 PM | #2 |
135
Rep 1,825
just did it.... its the exact same as the 3 series DIY.....nothing different except unplug the edc plugs to take out the shocks other than that its the same
10-25-2008, 07:01 PM | #3 |
123
Rep 1,973
Did you follow any torque specs for the bolts? I've been searching for this info, but nobody seems to care about this ... which I find quite hard to believe.
MDCT ... so you can drive and eat a hamburger at the same time. |
10-27-2008, 04:23 PM | #5 |
123
Rep 1,973
If I had torque specs for the bolts I'd be on this in no time. But since I don't I will wait until I get that info.
10-27-2008, 04:27 PM | #6 | |
57
Rep 1,798
Here are some pictures No special torque wrench needed. Just be careful of the bolts when you screw it back on later, as they need to be aligned properly or else you will knack the thread. Preparing for the springs. Replacing with new ones. Installed. |
10-28-2008, 03:36 AM | #7 |
123
Rep 1,973
A torque wrench isn't really anything special, but I'm just so surprised nobody has these values for the car. It's possible to over tighten or under tighten bolts isn't it?
10-29-2008, 03:33 AM | #8 |
63
Rep 2,427
Absolutely, this is THE most important part of working with your suspension (and other parts of the car). Bad things happen if you over or under torque it.
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
10-29-2008, 12:53 PM | #9 |
123
Rep 1,973
That's what I thought. So why don't people on here care? Haha. I'm about to call my SA for them.
10-29-2008, 01:47 PM | #10 | |
399
Rep 3,288
No disrespect to anyone here, but sometimes its easy to forget that appearances can be deceiving.
10-29-2008, 03:45 PM | #11 | |
123
Rep 1,973
10-30-2008, 03:08 AM | #13 |
63
Rep 2,427
i had mine lowered on H&Rs, took it to a shop that specializes in high performance cars. i'm assuming they torqued it down to the correct specs. but then again who really knows? i could never do this myself because i don't have the proper tools. (namely the lift, which i forgot to have installed when i built the house)
- John 3:16 |
10-30-2008, 03:48 AM | #14 | |
123
Rep 1,973
http://www.sears.com/shc/s/p_10153_1...000P?adCell=A3 And a breaker bar for those tough bolts ... http://www.sears.com/shc/s/p_10153_12605_00944202000P
11-10-2008, 04:45 PM | #15 |
71
Rep 396
Do you mean torque spec on spring perch or strut housing nuts? As for strut housing, I used 14 lb-ft. Over tightening it, you will be looking at a new strut housing. As for spring, I just screwed it in with Impact gun.
Good luck..By the way, I trust myself more than most performance shop. That was why I changed engine on my S2000 and CRX in my garage and not at the 'speed shop.' Again, I said most not all.. |
02-18-2009, 12:57 PM | #16 |
Bored at work....
890
Rep 5,391
Bump so I can find this thread in the spring also.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
02-23-2009, 11:51 AM | #17 |
do a wheelie!!!
154
Rep 929
Drives: E46 M3 - '72 2002 - '65 Impala
http://www.m3post.com/forums/showthread.php?t=183011
^ this is a waaay faster install, took me and a friend about 2 1/2 hours. and a total of about 8 bolts.
~Adam
