03-20-2021, 03:27 AM | #1 |
43
Rep 242
HUD info lost after using bimmercode expert mode
Hi !
After used the expert mode of BimmerCode to code m logo , tyre pressure in the instrumental cluster and xView I saw that the navigation’s informations and ACC informations were lost in Head Up Display I try to revert code with backup and also change the values but nothing change Also the sport mode on the hud is lost My car (g21 - my 2019) has 07.2020 firmware and I’m waiting to install 11.2020.. my car downloaded it but not install (maybe battery is not full charge) do you advise me to try to install the new firmware and see if it resolves or can I use the solution provided by ifr? https://g05.bimmerpost.com/forums/sh...740022&page=11 Many thanks |
03-20-2021, 06:17 AM | #2 | |
558
Rep 1,179
03-20-2021, 06:31 AM | #3 | |
43
Rep 242
I hope the same Now my car is under charge so I hope after two days ota upgrade will finally start It’s possible that 13v are not enough? after 13v the charger goes into a state of desolfication |
03-20-2021, 07:43 AM | #4 |
558
Rep 1,179
Someone posted that the charge won’t accelerate when the upgrade is pushed to your car, but can make the difference when it will allow you to kick-off the install.
03-22-2021, 07:56 AM | #6 |
43
Rep 242
No... today I installed new firmware 11.2020.50 but all informations about navigation and acc are lost in hud
Can someone send his configuration on a g21? Many thanks |
03-22-2021, 08:46 AM | #7 | |
558
Rep 1,179
DKOMBI4 - CAFD_00004508_004_005_013 - CB_HUD_FAS - Ausgelesen = nicht_aktiv (was aktiv) - CB_HUD_LIST_AUS - Ausgelesen = aktiv (was nicht_aktiv) - CB_HUD_LIST_AUTOMATISCH - Ausgelesen = aktiv (was nicht_aktiv) - CB_HUD_LIST_FAS_PERMANENT - Ausgelesen = aktiv (was nicht_aktiv) - CB_HUD_LIST_SPORT_AUS - Ausgelesen = nicht_aktiv (was aktiv) - CB_HUD_LIST_SPORT_FES - Ausgelesen = nicht_aktiv (was aktiv) |
03-22-2021, 12:20 PM | #8 | |
43
Rep 242
I will verify this night , I will download new ncd and I will compare it with ur data and old settings (and hope to solve ) Thanks! |
03-22-2021, 02:38 PM | #9 | |
43
Rep 242
Nothing With ur code i able to code new menu and also ACC info But I have no navigation info If u have g21 can u send me ur ncd file of dkombi? So I can compare with mine and see what’s the problem On navigation (hud) there are many voices Thanks Last edited by Fpgiuliano; 03-22-2021 at 03:35 PM.. |
03-24-2021, 02:46 PM | #11 |
43
Rep 242
Hi,
I’m trying to solve alone but I need ur help I verify these parameters in 4508 caf (dkombi) HUD_NAVI_ENABLE (aktiv) CB_HUD_NAVI (aktiv) PIA_HUD_NAVI (aktiv) Are all actives So I need someone who want share his caf file (I don’t think there are personal data inside...) or ask to someone to say me where I can download a “standard” version I also already try to compare old version of dkombi caf file 07.2020 (with work navigation info on hud) with new dkombi caf file 11.2020 but there are no differences (only unknow parameters, that were not there before ... I imagine new future implementations) I also compare hu_mgu files... nothing! So.. any suggestions on other ecu I can verify? thanks and sorry for the inconvenience |
03-24-2021, 03:04 PM | #12 | |
558
Rep 1,179
03-25-2021, 02:46 PM | #14 | |
43
Rep 242
On you car u have this parameter different from mine (only in hu_mgu): - adas_2dh_horizon_extension - adas_output_lane_pos And then this .. but I don’t think what they control Scr_anzeige Scr_anzeige_neu Zin_animation_config2 In the weekend I will try and see if I solve. Regardless of the result, I want to thank srbs73 for his willingness to help me |
03-25-2021, 03:20 PM | #15 | |
558
Rep 1,179
On the Scr_anzeige, this post suggests it’s to do with ad-blue warnings which would make sense: https://www.digital-kaos.co.uk/forum...ue-and-DPF-off The top two lines are part of the “auto adapt to route“ coding that IFR sent me. Allows the car to slow down at a turning without Nav enabled just by indicating. |
03-26-2021, 03:39 PM | #17 |
43
Rep 242
I verify all ecu but I found only this differences In dkombi
Disp_cc_ars_alive Disp_cc_ars_crc Disp_cc_ars_timeout Disp_cc_vdc_alive Disp_cc_vdc_crc Disp_cc_vdc_timeout But I don’t know what are these code Any news? |
04-04-2021, 09:35 AM | #18 | |
50
Rep 142
Drives: 2021 BMW M440i XD
Garage List 1984 Mazda RX7 GSL [0.00]
1999 Subaru Sambar [0.00] 1970 VW Beetle [0.00] 2024 BMW Z4 [5.00] 2021 BMW M440i Coupe [0.00] |
Do you mind sharing how did you enable xView? Thanks
02-05-2023, 07:22 PM | #20 |
356
Rep 365
I need closure. Did you solve your problem?
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
