03-15-2021, 09:59 PM | #1 |
70
Rep 263
Modding a 2018 Downpipes, Exhaust and Tune... CHANCES OF A BIG FAILURE AND A BIG BILL
Hi All,
I am ready to pull the mod trigger but want to quantify the risk of something going very wrong and getting a huge bill. I am based in the UK and will be using Evolve for all the mods; Downpipes Tune (110hp and 150 Torque) Spacers MSS lowering kit Can someone please shed some light on how often molded cars have experienced major problems? What have most the problems been? Engine failure? Gearbox failure? How much are those to fix? I really want to quantify the risk as best I can before pulling the trigger. I won't be dynoing the car or tracking it often, but I will be pushing her hard. Thank you The car currently has 25k miles and I will likely put 25k on her in the 5 years. |
03-16-2021, 03:51 AM | #2 |
982
Rep 1,797
Are you the original owner? I would be interested in the difference you will feel before and after the modifications. How will you use the additional power on public roads?
03-16-2021, 05:12 AM | #3 | |
70
Rep 263
I have to assume so much additional power and torque with no extra weight + the improvement in sound would likely make it feel like a totally different car. These mods plus spacers and mss lowering kit including fitment can all be done for the price delta of an m5 vs a comp. |
03-16-2021, 08:27 AM | #4 |
239
Rep 978
Mods
I do believe that everything you are doing is tried and tested by many forum members and you should be safe. My best advice - get an oil analysis if you really want to find out if you have any unusual wear going on inside your motor.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
BrntRubber69.50 |
03-16-2021, 03:31 PM | #7 |
70
Rep 263
Yes and upgrading all exterior trim to CF shortly along with some MSS height adjustment and some tasty new wheels hopefully.
Here are some of her in her 9em form. Here are the options: Last edited by BrntRubber; 03-16-2021 at 03:36 PM.. |
03-19-2021, 12:14 AM | #8 |
294
Rep 456
I did a lot of research before modding mine too. There's only one thing that seems to fail, rods. How many have failed is a huge mystery. I know of one for sure that was running 91 octane fuel on a 93 octane tune. Thats the only one I know of. I've heard engine builders say they have 5 F90s with bent rods they are currently rebuilding though. Not sure if it was true.
Two things mainly cause rod failures. The first is bad fuel. Run an E85 mix or meth injection to be safe. I did both. The second is too much torque at low RPM. besides first gear, I wouldn't go full throttle below 3500-4000rpm. The torque stays the same from about 2k rpm until 7k. When it's spinning faster, the rods are being stressed much less. If you do those things with a tune to 22-23psi, you should be very safe. If rods bend, the cost is basically labor to change the engine and the price of a used engine. I've seen them for 20k I think. Maybe less. New is 65k I've heard. If the rod doesn't go through the block you may be able to rebuild, but still looking at 15-20k.
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
BrntRubber69.50 BSdoc44.50 |
03-19-2021, 03:37 AM | #9 | |
70
Rep 263
I knownthe Evolve tune with downpipes is an additional 110hp & 150lb/ft on a stock vehicle. I am not sure how much psi that is. I have never mixed fuel or injected meth so I am not sure what's involved with that. I will nevertheless Race Race csr or take her to the drag strip. I just want to enjoy a bonkers fast sports sedan. |
03-19-2021, 07:09 AM | #11 |
982
Rep 1,797
The designers likely designed the car/engine to withstand a maximum load. Once that is exceeded your risk of components failing is much higher. I am not saying there is no risk without modification, but the risk with modification is likely much higher.
Maybe consider a car fast enough for you in stock form like a Tesla or Porsche Turbo S. This way you don't need to tinker with the design and will have a much lower risk of engine failure due to bent rods, crank shaft failure, etc |
03-19-2021, 08:16 AM | #12 | ||
70
Rep 263
This M5 is the all rounder family car. It was my understanding Downpipes and a tune that isn't too aggressive wasn't too hard on the car. I will only put around 2k to 3k miles a year on her. If the risk of a serious malfunction increases dramatically then maybe I will need to rethink the tune with downpipes. |
03-20-2021, 05:55 PM | #13 | |||
294
Rep 456
2018 BMW M5
