BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    2021 m5 jb4
      03-15-2021, 06:33 PM   #1
boost4breakfast
Drives: 992 GT3 24 M4C 21 M5C (gone)
2021 m5 jb4
Anyone realize any true gains on dragy or dyno after installing JB4 on the 21 models?
      03-16-2021, 02:25 AM   #2
EgemenComertoglu
Turkey
Drives: 997 ES1000+
i have got 2021 F90M5 , and i m curios about it also.
www.delphinhotel.com
      03-16-2021, 09:19 PM   #3
invidiousf90
Drives: F90 M5
subbed
      03-17-2021, 10:36 AM   #4
luchocamp
260
Drives: 18 BMW M2LPower
yes, from 11.1@124mph to 10.4@131mph map1 or map2 using 93 octane
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires
instagram @luchocampusano YouTube Lucho Campusano
pmatias03119.00
      03-17-2021, 10:46 AM   #5
Quinn A
122
Drives: 2016 M3
I will post up my 60-130 once i do the after, but seat of the pants the increase in power is huge, first and second gear are violent once boost hits, like i have to hold onto the wheel.
2020 M8 SMB full boltons and tune
2022 CT5-V Blackwing
2019 GT3RS full headers exhaust and tune
2022 Cayenne Turbo coupe Catless/ Tune
2022 Huracan STO
FSHNGRY2336.50
      03-17-2021, 11:24 AM   #6
AHall
982
Drives: 1993 Nissan 240sx
I would be interested in seeing the change in the torque curve. Sounds like a significant increase.
      03-17-2021, 12:04 PM   #7
Kponti
114
Drives: 2023 M8C comp
Great numbers for a 2021!!! Is this a Competition or base?
Was this on pump gas or something else? Any other mods?
Sorry for pummeling you with all the questions lol
      03-17-2021, 06:04 PM   #8
boost4breakfast
Will install JB4 and do dragy this weekend. have been enjoying the car stock
      03-18-2021, 08:30 AM   #9
Stano
Stano's Avatar
38
Drives: 2021 M5c
2021 comp.
Noticed no gains with only Tmap sensors plugged in.
10.92 Stock
10.88 Map 1 TMap only
10.47 Map 2 Tmap + EWG
All runs on draggy with 93oct and snow tires
      03-18-2021, 12:40 PM   #10
boost4breakfast
Originally Posted by Stano View Post
2021 comp.
10.92 Stock
when doing install, is it wise to plug Tmap only first and send logs to Burger?
      03-18-2021, 03:39 PM   #11
schnell1982
345
Drives: FAST
I would suggest their own support forum N54tech.com for technical issues. Terry is active on it as well as most of the JB4 clients
The harness connections will be installed based on which map and fueling, etc you are currently using.
I personally began with all connections except the waste gate sensors.
Multiple logs with Terry and currently running Map 3 with 6 gallons E85 mixed with California 91
      03-18-2021, 04:28 PM   #12
e92hunter
47
Drives: 21 M5
Install for the JB4 seems difficult with the wastegate sensors. Anyone know someone that can assist with this or teach me once in SoCal? I likely need to learn once so I can uninstall before dealer trips too.
      03-18-2021, 04:28 PM   #13
boost4breakfast
2021 comp.
10.92 Stock
I saw your post on N54tech, are you still getting drivetrain malfunction error codes?
      03-18-2021, 04:30 PM   #14
boost4breakfast
after the logs with Terry with the TMap, you connected the EWG and all was smooth?
      03-18-2021, 04:48 PM   #15
BMWDriverX
Drives: G12 750i X-Drive
Did you end up connecting the EWG sensors?
      03-18-2021, 05:23 PM   #16
schnell1982
345
Drives: FAST
I am still running without the wastegate sensors installed
Car runs perfect
In the installing instructions it is noted to leave them not connected until needed due to the possibility of having a fault code if they are not being used as they are intended to
1 thing with JB4 is that each car will run differently even with the same mods. That's where the logging comes into play
Here is recent info from Terry's support forum
https://www.n54tech.com/forums/showt...=52314&page=33
Some guys are running without but with the recent version 11 software it seems to be setting various fault codes.
This weekend I'll be updating version 11 and making logs with and without the waste gate connectors. Most likely they will stay installed. But for purpose of my original replies; I have not needed to have them installed with current configuration
      03-18-2021, 05:25 PM   #17
schnell1982
345
Drives: FAST
Nope. Still not connected
      03-19-2021, 09:52 AM   #18
Stano
Stano's Avatar
38
Drives: 2021 M5c
Yea I still can get drivetrain errors. I emailed my logs to them and they said everything looks good as far as logs go but mentioned nothing on the errors I get. I didn't press the issue any further because I've been busy with work and wasn't thinking about it. For that most part I can avoid having the error pop up. It's under certain conditions I've had them thrown.
I ran the car 2-3 weeks with just the TMAP plugs and felt no increase in power. Car is bone stock besides the jb4. I tried map 1 and 2 and noticed nothing. Car wasnt throwing errors and felt stock smooth.
Once I plugged in the EWG connectors the performance gains were very noticeable.
Once I get some time I wanted to log the car and try to make the error pop up and email it to them and see what they say. Codes thrown are usually similar like 120719, 12710,12071A with no description listed. Searching them I don't come up with anything either.
      03-19-2021, 10:55 AM   #19
schnell1982
345
Drives: FAST
Email Terry with the codes you are getting and let him know what you are experiencing. He is really good at getting back in a timely manner. Did they send you any log adjustments to make after what you sent them ?
      03-19-2021, 12:56 PM   #20
Quinn A
122
Drives: 2016 M3
Does anyone else have a bluetooth connection?
And if so does it keep reverting to map 0? I stay on map 2 but every few days despite no codes or me even touching the app it goes back to 0, super weird, and immediately noticeable
2022 Huracan STO
      03-19-2021, 02:44 PM   #21
LongBeachDinanFan
286
Drives: M3
App has something called last safety that tells you why the JB4 turned you back to factory tuning. For example if boost is higher than the limit you set in the app.
      03-19-2021, 04:13 PM   #22
Quinn A
122
Drives: 2016 M3
gotcha. will tinker with it.
2022 Huracan STO
