02-28-2021, 06:30 AM | #1 |
568
Rep 658
AA EL midpipe vs AA Single midpipe (both non-resonated)
Does anybody know the sound difference between AA EL vs Single midpipe?
Planning to pair AA midpipe non-resonated version with the stock muffler (or maybe I add Remus Sport later on if I need more sound). And I am not sure if I am prepared to wait for the EL midpipe as it is not available now and there is no guarantee they will deliver it exactly end of March. So maybe AA Single midpipe is the way to go Last edited by kart driver; 02-28-2021 at 10:40 AM.. |
02-28-2021, 11:13 AM | #3 |
2860
Rep 2,067
Aa single mid sounds amazing.
From what I understand EL sounds like a different car. So.. Single:best S55 sounds EL: Makes a whole new noise and isn't that s55 sound anymore |
02-28-2021, 12:24 PM | #5 |
568
Rep 658
I’ve done quite a research and here is what I found:
What is good with this video, you can here both midpipes in different modes: burbles on and burbles deactivated. When I listed to the video many times I originally thought that I the EL sounds a bit less attractive to my ears than Single, but later I found this post and now it looks like I know what the differences are and why Single might not be the best fit: ——————————— Yea, I went from Single AA w/ Dinan to EL w/ Dinan Differences below: Cold Start Single vs EL: the Single is less raspy / tinny during cold starts but mostly the same, both are loud as hell on cold start (I am valve open 100% time) Warmed up after cold start / long drives: Both eliminated most of the rasp , the AA single sounding lower / deeper up until 3k rpms, and then AA single gets really quiet inside the car and sound kinda dissipates. Quite the opposite for the AA EL; the EL gets louder as rpms get higher and starts singing as rpms go higher. You can actually hear the exhaust vs sounding like it being muffled. EL sings great straight six notes after warmed up. Cold pipes, warm engine: After pipes are warm, and if car is stopped for whatever amount of time allowing exhaust to cool but engine to still be warm (groceries, getting gas), the AA single and the EL both sound raspy for a few minutes until the pipes get warm again. I'd say the rasp is similar but the AA single is DEEPER sounding. The EL is definitely not as loud, smooth, or deep and bassy down on the lower RPMS as the AA single when pipes are COLD. If you try to rev an EL exhaust when the car is cold or pipes are cold, the tinny / raspy sound is definitely there and more pronounced than AA single. Warmed up, all is well again. I'd say slightly more tinny / rasp sound when cold for the EL, but when warm, the EL sings great turbo straight six melodies. Both setups are good. I can see why people would like one or the other. After owning AA single for 3+ years, the EL is what I prefer. The car just starts screaming (relative to other S55s) from 3.5-4k rpms. Not screaming like a GT3 or a straight piped e92 m3.. One thing to note is, the main issue before was if you wanted more sound without the EL, the car got raspier, nastier, and honestly quiet atriocious sounding as the exhaust setups got louder (with deletion of more cats, downpipes, resonators). Not the case anymore, EL really smoothed out the sounds up top. taken from here: https://f80.bimmerpost.com/forums/sh...postcount=1696 ———————- So for me the summary is as follows: AA SINGLE midpipe: pros: deeper sound than EL cons: but the deeper sound dissipates at high revs AA EL midpipe: pros: the volume of the sound increases progressively when you add revs cons: might produce less attractive sound when cold Last edited by kart driver; 02-28-2021 at 12:33 PM.. |
02-28-2021, 01:05 PM | #6 |
Enthusiast
45
Rep 40
Hello, I had the chance to hear both and buy either one. There are advantages and disadvantages for both of them. Here is a list:
AA Single: - Removes a decent portion of the rasp from the exhaust note. - Is cheaper by $400-$500 - Much easier to find and get (as the EL is back-ordered from most sources, if not all) - Lighter than the EL system. - Pairs with aftermarket downpipes extremely well. - Easy install AA EL: - Removes ALL rasp and makes the engine sound incredible. - More expensive - Hard to find - Heavier than the Single - Does not pair well with aftermarket downpipes and makes the engine sound worse if used in tandom with some DP pairings. - Decently easy to install, but still more difficult than the single (two pipes duh) There are a few videos going around where the EL paired with VRSF downpipes sounds like a tin can and you can only hear rasp. I assume this is due to the EL system being specifically designed for the stock DPs, and any alteration in DP length will result in many different and probably unexpected results. Last edited by Iamlemon; 03-01-2021 at 12:30 PM.. Reason: Accuracy |
02-28-2021, 02:39 PM | #7 | |
568
Rep 658
I am keeping the downpipes stock without any doubt. And most likely the stock muffler as well. The price difference of mid-pipes is irrelevant in my case. What worried me was if with AA Single midpipe the sound volume dissipates with higher revs. But I just found the following video and I am absolutely fine with it at high revs. I will most likely disable the burbles and will consider the sound to be perfect. |
02-28-2021, 04:20 PM | #8 | |
Enthusiast
45
Rep 40
02-28-2021, 04:40 PM | #9 | |
568
Rep 658
Thanks for the invitation, but I am based in a different part of the globe )) Weight saving or power increase is of no importance to me. I just want to improve sound a bit. |
03-01-2021, 09:46 AM | #10 |
BimmerPost Supporting Vendor
24198
Rep 190,807
AA single gives it a rasp-free tone, with a deeper sound.
The Equal length midpipe makes the car sound almost non-turbo. With a much deeper mid-range tone Both are quality options, if you are getting catless downpipes in the future the single is the better option for you.
Rumbloki176.00 |
03-01-2021, 01:34 PM | #11 | |
568
Rep 658
Thanks for the feedback. Going with Single version. |
03-01-2021, 08:11 PM | #12 |
24198
Rep 190,807
My pleasure, you won't regret it
03-11-2021, 07:05 PM | #13 |
Rep 28
Ok, I searched and didnt see what I was looking for. Anyone done a EL or Single Mid Pipe Resonated? I just want a tad louder, but also less rasp. The EL an Single still have a pretty decent amount of rasp IMO. The resonator would deepen it, but will it to be too close to stock to be worth it?
I only want to do midpipe and keep stock DP/Suitcase |
03-12-2021, 04:51 PM | #14 | |
568
Rep 658
I have ordered Single Midpipe non-resonated and plan to pair it with OEM muffler. My idea is to turn off the burbles and I hope this will give exactly the same result as you are looking for. |
03-12-2021, 10:56 PM | #15 | |
1045
Rep 605
Drives: M2C
I got non-res and am happy with the sound. It's not obnoxious while just driving around town but it really comes alive as you get into the higher rev range. |
03-14-2021, 07:29 PM | #17 |
98
Rep 196
Anyone in Utah with an M2/3/4 with either of these on their car willing to let me come listen?
2019 F87 M2C - DCT / 10mm spacers w 246/265 / RW lip / Suvneer skirts / PSM spoiler / BMW diffuser / 3M gloss black
03-16-2021, 08:34 AM | #18 |
10
Rep 164
03-16-2021, 11:27 AM | #19 |
568
Rep 658
03-16-2021, 04:49 PM | #21 |
568
Rep 658
03-16-2021, 08:13 PM | #22 |
10
Rep 164
