02-21-2021, 06:19 AM | #1 |
55
Rep 121
F36 side skirt extensions
Hi, I fancy fitting some genuine side skirt extensions to my F36. Messaged a seller on EBay who said they are just glued on and the fixings were not included. Checked the BMW instructions and that says use the fixings (15 a side I think) and glue.
Don't really fancy using glue as it would be messy if they ever had to come off. So my question is, how did you fit yours? Thanks! |
02-21-2021, 07:09 AM | #2 | |
1388
Rep 2,128
Since fitting, I have used screws, washers and bolts to make sure they don't budge. They also have a thin strip of double sided tape across them.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
02-21-2021, 07:12 AM | #3 | ||
55
Rep 121
02-21-2021, 07:13 AM | #4 | |
1746
Rep 2,088
You could use small bolts but they would be subject to corrosion. They shouldn’t be glued as such. The process is to use the 3M tape to align the blade and then use plastic rivets to secure (all which come with the blades). If the fixings are missing, the rivets are available from BMW and are not expensive. |
02-21-2021, 07:15 AM | #5 | ||
55
Rep 121
02-21-2021, 03:06 PM | #6 |
Crustacean denier
395
Rep 582
3M tape is how I did mine on the F31. The blades for that model have a raised strip toward the inner side, you sort of hook it behind the panel and it lines up perfectly.
02-22-2021, 02:09 AM | #9 | |
461
Rep 1,303
Although in hindsight its was probably easier to just remove the sideskirts from the car to fit them on a bench. |
02-22-2021, 02:29 AM | #10 |
Crustacean denier
395
Rep 582
02-22-2021, 03:48 AM | #11 | |
55
Rep 121
