BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 2007 E91 Key Fob Issue
      02-12-2021, 02:50 AM   #1
Chromedome73
Drives: 2007 E91
Hi,
I've got a 2007 E91 with a non replaceable key fob battery.
These last couple of days its stopped working & the warning light is on the dash, I've tried to charge it on a toothbrush charger but no luck (if that is even a thing) I've been using the key to get in.
Last night & this morning it both unlocked & locked the car with the fob & no warning light on the dash, I get to work & its not working again.
I have ordered a new battery off Ebay just incase
So is it the fob battery failing or could it be something else?
Also my N/S footwell light flickers on/off as I drive, but thats probably a loose connection
Cheers
      02-12-2021, 05:56 AM   #2
therealdb1
106
Drives: Graphite E93 335i
Cheers
Are you asking if bad luck is a thing?
Yes it is and you get plenty with these cars!
Sounds to me like your battery in the fob is knackered and cannot hold a charge. They do not last forever and it is likely to be 14 years old this year.
You just need to source a new battery which it sounds like you have done and solder it in. It is not a difficult job.
Just make sure the new battery is rechargeable and not the normal single use coin cell that many fobs take.
      02-12-2021, 07:24 AM   #3
Chromedome73
Drives: 2007 E91
Ha ha , i meant the toothbrush charger
Yeah I have a battery on its way to me, I just wanted to make sure it couldn't be anything else.
Cheers
      02-12-2021, 01:29 PM   #4
Arch Stanton
49
Drives: BMW 335i touring
I had that with the spare key I rarely use, it took a few long runs using that key before it recharged enough to stop the light. All good now.
      02-13-2021, 04:34 PM   #5
0l0dom0l0
69
Drives: BMW E92 330i
Have you got a spare key?
New genuine ones direct from BMW aren't mega money, I think mine was £180. Easier than being stranded.
