02-07-2021, 01:59 PM | #1 |
149
Rep 373
Need help with 2 wheel dive setting
Ok so I read the manual, made all of the adjustments into M2 drive, sport plus etc, including 2 wheel drive selection, but when I press my M2 button (twice) it still shows 4 wheel drive on the cluster. What am I doing wrong?
02-07-2021, 04:18 PM | #2 |
265
Rep 720
You’re sure you’ve got DSC set to “Off”, with 2WD set up for your M2 button? I haven’t used it yet, but I understand you used to have to press the M button twice if you have it set to any of the DSC off settings—once to request and again to confirm—while you are driving.
02-07-2021, 04:20 PM | #3 | |
701
Rep 778
02-07-2021, 04:29 PM | #4 | ||
982
Rep 1,797
02-07-2021, 05:39 PM | #5 | |
4425
Rep 4,109
Did you consciously select 2WD within iDrive? If not, that's your problem. |
02-07-2021, 05:48 PM | #6 | |
106
Rep 240
I did the same error at the beginning
F90
02-08-2021, 07:51 AM | #7 | |
149
Rep 373
02-08-2021, 07:53 AM | #8 | ||
149
Rep 373
02-08-2021, 07:54 AM | #9 | ||
149
Rep 373
02-08-2021, 09:32 AM | #10 | |||
We are all Longwong
138
Rep 940
Drives: F90 CP LCI
02-08-2021, 01:21 PM | #11 |
31
Rep 48
I've reported the issue to my dealer. I'm 100% sure it appeared after "Technical Campaign 0012470500 Programming the control units". I absolutely agree that its a security issue. I suggest more people report it so it gets a higher priority @ BMW.
02-08-2021, 06:28 PM | #12 | |
701
Rep 778
flanast148.50 |
02-08-2021, 10:20 PM | #13 |
56
Rep 72
BTW there is a new software update that fixes this. I had it applied a while back and it now changes in the Instrument cluster to match the setting requested.
02-09-2021, 05:59 AM | #14 |
149
Rep 373
I'm always hesitant to have the dealership update my software. I'm afraid they will remap the ECU and the car won't perform as it does now
02-09-2021, 06:29 AM | #15 | |
982
Rep 1,797
02-09-2021, 08:58 AM | #16 |
We are all Longwong
138
Rep 940
Drives: F90 CP LCI
I'm on the latest software version and can't replicate this bug. If it existed in the last version, it has been fixed. Curious if this was uniform for the last version or just partially effects certain models.
