TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Front end whine
      02-06-2021, 06:16 PM   #1
ramp
28
Drives: E91, Lemans Blue
2011 BMW 328i  [0.00]
Front end whine
2011 E91 M Sport, 6 speed manual 134,000 miles
When traveling above 40mph and I let off the gas, there is a very noticeable whine from what seems the front end. Give it gas and it goes away. All fluids were changed just a few months ago. I don't think it's a wheel bearing.
So is this differential noise when not under load?
      02-07-2021, 06:16 PM   #2
ramp
28
This may be it.
      02-17-2021, 05:23 PM   #3
ramp
28
Replaced front axle, noise still present.
The report from the shop is the front differential is the problem. Oil smells burnt.
2500.00 quote to replace differential and oil pan gasket.
Is there a difference with front differential between wagons or sedan with manual 6 speed?
      02-21-2021, 10:12 AM   #4
kenmar
21
Drives: 335xi
I had similar problems on an older BMW and it was the diff bearings which I had replaced. No problems for years after the repair was done.
Go to any good tranny shop and they can repair it cheaper since they will replace the worn out parts rather than just R&R. It will still be a hefty repair bill, much more confidence-inspiring than bolting in a used diff with an unknown service history.
For your Q about different diffs, check the P/N on realoem.com; that will answer your Q more definitively rather than relying on rumours
