BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > When to change antifreeze? How many liters?
      02-06-2021, 09:04 AM   #1
rohe
rohe's Avatar
Drives: BMW F20 LCI
I have a B38 Engine 2015 118i LCI vehicle. The Antifreeze Water level appears below. Should I do a complete replacement? How many liters should I buy? Or is it enough to just add?
      02-06-2021, 07:15 PM   #2
No one
1045
Drives: F21 118i
See your manual. It does not look like replacement is ever necessary, just to add should be fine (provided there's no leak to fix). Mind the concentration: BMW coolant takes distilled water to be 50/50 mixed with (see the bottle label ).
      02-07-2021, 03:19 AM   #3
rohe
rohe's Avatar
Drives: BMW F20 LCI
hi, the manual says "consult your dealer. Not all liquids sold are suitable.".
I think I can use this product directly. Also without adding water.
https://partsfinder.bilsteingroup.co...cle/febi/24196
      02-07-2021, 04:39 AM   #4
No one
1045
Drives: F21 118i
Hi,
It's best to add the same one you have. That's buy from a dealer (if you still have the factory one). At the very least the colour must match.
While having the car serviced the last but one time I had just the coolant added (free of charge, so I made no water comment ). The last time I had the car serviced (an official service every time) the mechanic checked the density and made no comments on it. So a little of undiluted is fine but for colder climates only, as it increases frost resistance. Keep in mind that in a warmer climate higher concentration should make it more vulnerable to boiling.
      02-07-2021, 05:28 AM   #5
rohe
rohe's Avatar
Drives: BMW F20 LCI
Hi,
thank u very much for your help
      02-07-2021, 06:08 AM   #6
No one
1045
Drives: F21 118i
And by the way, regarding how many litres it takes to replace. I have some VIN-based info regarding my car (N13 engine). It says 7 litres of antifreeze. FWIW
      02-07-2021, 06:10 AM   #7
rohe
rohe's Avatar
Drives: BMW F20 LCI
my vehicle B38 motor VIN:5C86831 When I look at it from here, it comes out 1.5 lt. https://bimmercat.com/bmw/en/search/vin_search/5C86831
      02-07-2021, 06:30 AM   #8
No one
1045
Drives: F21 118i
The link (your link, your VIN) says "7.70l" to me.
      02-07-2021, 06:32 AM   #9
rohe
rohe's Avatar
Drives: BMW F20 LCI
I'm looking at line 8
thank u
