Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Staggered set up XI
      02-04-2021, 02:55 PM   #1
Mobius One
Drives: E90 328i Xdrive
Staggered set up XI
Hello all, easy quesrtion for everyone.
I am running a staggered wheel set up:
Front 18x8.5 et 30 with 225/40r18 tires
rear 18/9.5 et 35 with 255/35R18 tires
both are bridgestone. I am not crazy about the bit of stretch and would prefer a bit more tire under the wheel. What's my next width up while still maintaining the 1% difference for the 4WD
235/40
275/35?
Thank you for your help!
      02-05-2021, 09:39 AM   #2
donut_boi
998
Drives: 2015 F85 X5M DGM
235/40
275/35?
Hi, here are your next two step up options:
- 235/40/18 and 265/35/18
- 245/40/18 and 275/35/18
Happy modding
2015 BMW X5 ///M | Donington Grey | Aragon Brown
MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby
2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown
      02-05-2021, 03:05 PM   #3
Yotaismygame
Yotaismygame's Avatar
130
Drives: 2008 335i e92 (Beam)
235/275 is perfect for your setup.
      02-08-2021, 12:10 PM   #4
Mavd24
Drives: none
Is 235/275 still within the 1%? The post above says 235/265 or 245/275?
Let me know more your recommendation of 235/275 ? Thanks !!
      02-08-2021, 04:12 PM   #5
Mobius One
Why is this perfect and does it stay within the tolerance for Xdrive? Really appreciate the help.
      02-08-2021, 05:29 PM   #6
Yotaismygame
130
I had to rethink what I said. You're running an 18" wheel. I was talking about a 19" setup. For 19s 235/275 are the same diameter. For 18's you'll be at +.8% difference. or -.4% with 235/265 back tire will be slightly smaller.
My brother is running this setup on his 2012 e92 xdrive: 19x8.5 et 33 235/35 tires & 19x9.5 et35 275/30. Pretty much perfect. He's still on stock suspension.
Looks like you're in an e90 so you have even more room in the rear for a wide tire.
      02-08-2021, 05:31 PM   #7
Yotaismygame
130
https://tiresize.com/calculator/
Helpful for figuring out tire sizes
      02-08-2021, 06:15 PM   #8
lilred911
Drives: Prius
I'm running 225/40 and 255/35 no issues, was running 235 255 and the transfer case didn't like it. 235 265 or 245 275 is safer imo.
      02-09-2021, 10:12 AM   #9
Yotaismygame
130
235/255 is -1.6% dif. Could see why that didn't work.
      02-09-2021, 07:23 PM   #10
Mavd24
Drives: none
Ahhhhh. Great updates. Thanks. OP says so too since he’s sitting next to me. Lol. Appreciate the help
