Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications I want to add some noise to the 330i
      01-26-2021, 04:14 AM   #1
franky818
223
Drives: e90 2010 , g20 2020
I think this is my second topic now ... I am too old to be getting pulled over by LAPD . But never too old to unleash some noise ... I hear there are options to add some noise ? But still quiet in comfort mode ... I don't want anything too loud.. but to get a little louder than just "stock"
Help me add some noise to this baby
Appreciate 2
      01-26-2021, 08:46 AM   #2
sanch8
67
Drives: 2019 330i
Have you considered an MPerformance or an aftermarket exhaust?
      01-26-2021, 10:34 AM   #3
vTuga
vTuga's Avatar
Portugal
92
Drives: 2020 BMW 330e G20
Your car sir is proof that a G20 BMW doesn’t need an M sport package to look drop dead gorgeous. Congrats 👏
franky818223.00
      01-26-2021, 08:41 PM   #4
franky818
223
I don't want to spend anything more than 500$ ... just want a little more noise don't care about anything else .
      01-27-2021, 02:15 AM   #5
franky818
223
Will res delete give a check engine light? I heard that's the cheapest solution ... it is a lease
      01-27-2021, 04:42 AM   #6
Knifeedge2k1
147
Drives: BMW G30 520i 2019
catless DP is about 500 usd
you can always swap it back at the end and resell the part
gives a performance boost too
      01-27-2021, 12:08 PM   #7
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
It won't give you a CEL. But it might drone. I've done lots of googling and people are divided. Some say a res delete makes the car drone. Others say a muffler delete does. I might do a muffler delete since it will make the exhaust louder (doesn't muffle the sound as much) whereas a res delete might make it drone (more resonance?). Ofcourse, I could be very wrong.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-28-2021, 12:50 AM   #8
franky818
223
Is there a catless dp that will add sound &
Its plug and play? My mechanic can install anything but if there is cutting and welding he's out and at that point I rather just take it for a res delete at a local exhaust shop
Please link to a few options
      01-28-2021, 03:37 AM   #9
Don76
171
Drives: BMW 320i M-Sport
A catless DP will add noise, but will throw a cell light and put you in limp mode. You'd need a tune to ignore the cell.
There are sports cat DPs that will add sound without the cell but they're more expensive.
The sound from a catless DP is lovely
      01-28-2021, 03:42 AM   #10
franky818
223
What do you mean I need a tune? I did tune my car through mission tuning lol . Does that count? Also I hear catless will be too loud . I was thinking catted? Any recommendations?
      01-28-2021, 12:14 PM   #11
VipinLJ
Petrolhead
VipinLJ's Avatar
Yes. You'd be better of going catted because of emission laws in CA and stuff. Plus, with a stage 1 tune, if you go catless, there's a good chance you'll get a CEL (even though it won't affect the way your car drives). A stage 2 tune will be able to code that out iirc.
Problem is catted DPs are more expensive. If you just want an increase in sound, get a muffler or res delete.
PS : Just noticed Don76 said the same thing I did. My bad.
Current:
      01-28-2021, 12:22 PM   #12
Don76
171
I don't think a catless DP is too loud, but it's all a matter of taste and personal preference.
Get on YouTube for some research and decide for yourself.
As for the tune - I can't speak for your tuner, but most would be happy for you to return and have the required tweak to the map to delete the cel. A few beer tokens would be reasonable.
Most tuners here in the UK will flash back to std for a trip to dealer and reflash back afterwards for free.
      01-28-2021, 08:58 PM   #13
SeattleStefan
Drives: BMW 330i X-Drive
Be warned too that if you do go for a Resonator Delete and/or muffler delete, BMW has 3 inch pipes running from the downpipe through the resonator and down through the rest of your exhaust, so a lot of exhaust shops can't work on it. At least that's the case in Washington State, most shops will only do up to a 2.5 inch pipe.
      01-30-2021, 08:29 PM   #14
franky818
223
So I did resonator delete but it's not that noticeable other than some noticeable pops at 4000rpm .... any rec? Should I do a muffler delete or order a catted/catless down pipe? Thanks in advance !
      02-04-2021, 03:57 PM   #15
ghostB48
Drives: 2021 BMW 330i
I just put in catless downpipes and there is such a big difference. Significantly more pops and bangs when both upshifting and downshifting. I am kinda wishing that I have taken the resonator out so I can get more, but in your position you should definitely put in a downpipe.
Also, I had went and bought spark plug defoulers from autozone "Dorman 42009" comes in a back of two for like $6. You can attach these two together and place the o2 sensor in to not get a CEL.
      02-04-2021, 08:36 PM   #16
franky818
223
Which Downpipe ? Also what car do you have and where are you from?
      02-04-2021, 11:13 PM   #17
ghostB48
I've got the 2021 330i and I got vrsf catless downpipes.
lol just noticed it says ur from SFV i'm right here in the 818 as well.
franky818223.00
      02-07-2021, 08:05 AM   #18
dave72
BMW M2
dave72's Avatar
497
Drives: BMW G87 in order
I made a cut-out and gives a nice deep sound, can do it on-off. And I still have the original muffer
VipinLJ1941.50
      02-07-2021, 11:38 PM   #19
Ghozthunter
Eleet Tech
Ghozthunter's Avatar
Drives: a bimmer
Any sound clips of how it sounds?
      02-08-2021, 08:00 AM   #20
Ziggystar40
Drives: BMW 330i
great idea. id do the same
      02-08-2021, 12:57 PM   #21
lakers2426
Drives: 2020 330i M Sport
Remove the resonator and code sports plus. Pops and burbles a lot, almost as much as a b58 when in sports plus. Exhaust sound is maybe a bit louder in a subtle way but not much, drone increase is very little and worth it. I believe sports plus opens the exhaust flap.
If you want a big difference your probably gonna have to spend big money on an after market exhaust, or at the very least remove the muffler, which might sound a little cheap, but not sure as I have never heard it.
      04-12-2021, 03:42 PM   #22
egor.bruilo1
egor.bruilo1's Avatar
Belarus
11
Drives: BMW 330i G20
Search this Thread:
Advanced Search
g20
