Alternator/Regulator or Battery
01-13-2021, 11:17 AM | #1 |
72
Rep 191
Went into limp mode on the freeway and car wouldn’t start and got 2 codes (2E98 and 2DEB, but fired up 10 minutes later and I was able to get home. Ran errands later in the day and car died with very little juice/screens flickering and key fob getting stuck. Same 2 codes + 2A1A, 2DEC and 2E83. So do I need a new alternator? Battery is 2 yrs old and I didn’t have any signs of it getting low prior to today.
2009 BMW 335i 6MT/MHD Wedge Custom E60/VTT Inlets/VRSF DP's/VRSF 7" HD FMIC/Boost Concepts FPM-1 E85 Fuel Pump/BMS DCI/BMW PE/ER CP/Tial BOV/BMS OCC/RB PCV/19" Gunmetal Forgestar F14's Deep Concave/Michelin PS4S/Ohlins R&T Coilovers/Swift Springs/Spec Stg 2+/Icon Motorsports M3 Rep Front Bumper
01-13-2021, 10:10 PM | #2 |
19
Rep 91
Drives: (2007 BMW 335i E92)
I would get the battery tested before making any decisions. It does sound like a charging issue due to your flickering screens and random codes. It's likely that if the battery was the issue your car wouldn't have enough power to start at all. There should be a voltage regulator on the back of the alternator that can be replaced. I've had some friends with similar issues and typically the voltage regulator is the culprit. But I would definitely suggest getting your battery tested, and if it's not faulty take a multimeter to the alternator output and see if it's putting out between 13-14.6 volts while the car is running.
01-14-2021, 08:36 PM | #3 |
72
Rep 191
I got the car towed and battery is dead. I charged it for an hour and only getting 11.6 volts on the battery with the multimeter. I couldn’t even fire the car up to check to see if the multimeter spikes over 14.4 with the car idle.
01-15-2021, 03:30 PM | #4 |
19
Rep 91
Leave a charger on it overnight if you can, otherwise you'll need a new battery if that one is toast so you can troubleshoot and figure out why your battery died.
01-29-2021, 12:13 PM | #6 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
