Rear downpipe front o2-too close?
01-12-2021, 05:04 PM | #1 |
101
Rep 304
Hey everyone. Finishing up my turbo install and am revisiting the vrsf downpipes I installed previously. I found the front o2 on the rear downpipe to be waaaay too close to the water pipe previously, but thought maybe it was just because I didn’t have enough space to work before. I have the subframe out still currently and it doesn’t seem as if there is anything I can do to get the o2 to not touch slightly the water pipe...is this normal?
01-12-2021, 06:42 PM | #2 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
I agree that your o2 sensor is far to too close to the water pipe. What brand of Turbo did you buy? Obviously, they are clocked a little different. Does your outlet match up to your FMIC correctly? |
01-12-2021, 07:01 PM | #3 |
19
Rep 91
Drives: (2007 BMW 335i E92)
I don't remember mine being this close to the water outlet, could possibly be a defective downpipe but you never know... The pipe shouldn't be more than 100 degrees Celsius at any time so it won't be enough to melt the shielding/insulation. I would be concerned about fraying over time maybe but that could likely be solved with some sort of heat wrap. As long as you're 100% sure that the downpipe is installed and clocked correctly then I wouldn't be too concerned about it.
01-12-2021, 07:34 PM | #4 |
101
Rep 304
Both oem turbos and my new pure 600’s are fitting the same. Everything lines up with the exhaust, and the o2 is just super close...I’m betting the bung wasn’t out in the right spot...There really isn’t any way to rotate it and have it line up with the rest of the exhaust, old
Turbos or the new ones. |
01-12-2021, 08:00 PM | #5 |
1209
Rep 2,476
Did you buy them new/from an actual vendor? Or used and/or a private seller? Do they have the VRSF logo on them? Older ones didn't, newer ones do. If you bought them from a private party, and they don't have the VRSF logo on them, it's possible you got something other than VRSF pipes.
01-12-2021, 08:21 PM | #8 |
101
Rep 304
I’m sure they have nothing to say about it. Still waiting on a response as to why my outlets didn’t come with o rings...I’ll just assume poor quality like every other product Iv ended up with.
01-13-2021, 04:45 AM | #9 |
469
Rep 1,536
I had some installation problems with the new batch of 335i VRSF downpipes too. It seems they made changes to the V2 pipes at the end of last year without mentioning anything, one of the exhaust bolts now needs shortening as they altered the angle of the flange on the front pipe.
The flange on my rear downpipe is also angled slightly wrong so it causes the downpipe to clock towards the subframe when tightened. I've contacted VRSF about it but they aren't really interested. I have their downpipes on my Z4 which fit perfectly but either their quality control has failed or they made a design change without properly testing, either way I'd point new customers in the direction of other brands in future. |
01-13-2021, 07:08 AM | #10 | |
101
Rep 304
01-14-2021, 08:58 PM | #12 | ||
1903
Rep 6,968
I have MMP Catless Downpipes. They fit just fine. No issues. https://mmp-e.com/products/3-catless...2008-2009-2010 Their website says they will be back in stock in late January. $200.00 for a set is a great deal. |
01-15-2021, 06:24 PM | #13 |
19
Rep 91
I'm running MMP downpipes as well, did have a fitment issue at the mid-pipe flange though, it seems as though they are pointed away from each other which caused an exhaust leak when I first fit them up, shortly after I bent my mid-pipe flange to line up and no exhaust leaks. That's my only complaint about them otherwise I would be confident that they fit pretty well. I've heard a handful of people say that the new VRSF pipes don't fit very nicely but the V1s were really good. MMP downpipes also seem to be significantly cheaper than VRSF.
01-16-2021, 06:56 AM | #14 | |
469
Rep 1,536
I thought paying more for VRSF downpipes would save me the hassle of bending pipe but apparently not. Really disappointed with VRSF support. Tiago just gave me the usual replies telling me to check the install then after I provided additional detail they went silent. I have heard of suppliers dropping their products because of quality issues and now I understand why, if you want cheap then MMP seem to be the best route and if you want perfection then go with someone like ARM. What did you use to bend the midpipe flange? I've got access to a workshop so could possibly do it myself. |
haaken675101.00 |
01-16-2021, 07:25 AM | #15 | |
101
Rep 304
01-16-2021, 08:18 AM | #16 | ||
393
Rep 972
My shop recommended the Cobb dps however I had already done my research and heard a lot of fitment issues with those as well. If vrsf won't sent you a replacement pair, I'd see if an exhaust shop can modify your midpipe so they line up correctly. You really don't want these touching the subframe... or leaking. The smell is strong enough when Catless without leaks.
Instagram : @Bimmer_bro
01-16-2021, 09:22 AM | #17 | |
469
Rep 1,536
I wouldn't even need a replacement pair, just the rear one. It's not ideal having to mess around with replacement parts but I'd be happy enough if they tried to put it right. Given the OPs issues and mine, I think there's some major quality control issues at VRSF. It shouldn't be that hard to replicate some pipes and verify fitment. |
01-16-2021, 02:18 PM | #18 | |
19
Rep 91
02-02-2021, 09:17 AM | #19 |
Rep 16
I recently received my set of V2 downpipes I ordered directly from VRSF with the rear O2 sensor bung/plug on the front turbo pipe so badly crossthreaded that it destroyed the threads on the plug as well as inside the bung just to get it out. VRSF has no listed contact phone number and only has a weak message relay system on their website, so it's pretty heavily implied that they couldn't care less about customer service or issues with their products after they've been paid.
I actually received an initial response from them, but judging from it's contents I have a strong feeling I'm about to get the run around...I replied within an hour or so and haven't heard anything back since yesterday. At a minimum VRSF has very poor quality control and bad customer service. I haven't even tried lining up the exhaust connections yet, but hopefully that isn't an issue as well. Unless this experience really turns around, I will definitely not be buying any other parts from them for the rest of my build(s). |
02-02-2021, 09:41 AM | #20 | |
469
Rep 1,536
I'm certainly going to update either way once the new pipe turns up and I can get it fitted. I'm not happy that I've had such a simple fitment issue that should have been picked up on a jig but if the new pipe resolves it I'll give them credit. |
02-02-2021, 09:53 AM | #21 |
700
Rep 1,227
Oh man, it's a good thing I looked at this thread because I literally have the VRSF DP in my cart along with new clamps and seals and was contemplating upgrading to the 7.5 inch stepped FMIC to upgrade my 5 inch i have now. . Now I'm wondering if I should just look elsewhere for these parts.
02-02-2021, 04:33 PM | #22 | |
101
Rep 304
feuer4275.50 |
