01-08-2021, 07:00 PM | #1 |
Remove Before Flight
6822
Rep 1,611
Searching for 70mm bolt-on exhaust tips
Considering the new Dinan exhaust for the M2C, but not a fan of the tips.
I believe any bolt-on in 70mm will work. Ideally, I'd like to find something similar to the BMS replica black-chrome slash cut's I currently have on the stock exhaust (see below): Any suggestions? Not a super huge fan of carbon, and I think I like the look of the slash cut. Been searching today, but my Google-Fu is weak. TIA-- |
01-10-2021, 11:01 PM | #2 |
259
Rep 151
The Dinan tips definitely look a little unfinished, and I think it would serve them to offer something that looks more factory, but just a little beefier. Although you mentioned you're not a fan of carbon, these could be a possibility:
https://autotecknic.com/products/aut...10120584757290 I haven't seen any photos of anyone running these, or any other tips with the Dinan exhaust for that matter. Please post photos of your future set up!
2019 M2 Competition 6MT - ED October 5, 2018
2018 Honda Accord Sport 1.5T 6MT (daily driver / family hauler) |
01-13-2021, 12:41 PM | #3 | |
390
Rep 291
01-13-2021, 01:27 PM | #4 | |
6822
Rep 1,611
1. Tip length is 3.75". If including the neck where the clamp sits, add an additional 1.378" to that length. 2. Tip ID is 70mm. 3. Tip OD is 4". |
01-13-2021, 01:50 PM | #5 |
320
Rep 295
I have the Dinan exhaust with the black tips and before I purchased I was sure I would swap them out but they have grown on me.
Depending on how much you are lowered you may need to be careful about the new tip length as the bottom of the stock tips already rub going up a steep incline. I'm low enough [max low on Ohlins] where the stock exhaust ball-sack also rubbed going up steep inclines like my driveway. . |
01-16-2021, 09:25 AM | #6 |
54
Rep 139
01-16-2021, 09:32 AM | #7 |
6822
Rep 1,611
Well, the tip search is on (permanent?) hold--
Just got the email. The Dinan exhaust slipped another month..... AGAIN. Now they're saying Feb 19. Which is (coincidentally, I'm sure) exactly a month after the last date that I was given. They're selling a fiction as far as I can tell. Hmmmmm. |
01-16-2021, 09:41 AM | #8 | |
390
Rep 291
01-22-2021, 07:19 AM | #9 |
192
Rep 240
ARM motorsports makes a 90mm tip that comes in silver or black. They are held on by an allen screw so they fit a variety of exhausts. I think the black ones look similar to Dinan but <$150. I had them on my F80 and moved them to my M2C.
01-22-2021, 12:13 PM | #10 | |
390
Rep 291
Can you take a few pic on your M2. Especially on the side view. Thanks in advance |
01-22-2021, 12:44 PM | #11 |
53
Rep 204
Do you know if these tips will fit a OG M2? Are the diameters the same as the m2c?
01-22-2021, 01:03 PM | #13 | |
192
Rep 240
Fuji550i389.50 |
01-22-2021, 01:34 PM | #14 |
192
Rep 240
Sorry OP. Just realized i misread the original post. Thought you wanted Dinan look without Exhaust. Not Dinan exhaust with dif tips. my b
01-23-2021, 12:47 AM | #15 | ||
390
Rep 291
