Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Bank 2 misfires after wot pull
      01-06-2021, 05:09 PM   #1
Louayea
Drives: Bmw 335is Dct
After doing a wot pull I got a misfire code and other codes taht won't go away, misfire 3,4,5. Reset my codes and still pops up even at idle.Womt go away I thought mosfits but I have a 2011 335is so msd81 I have no idea why it is misfiring .
      01-06-2021, 05:18 PM   #2
Saif2018
973
Drives: E90 335i
When were the plugs and coils changed?
I would start there first,
      01-06-2021, 06:07 PM   #3
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Bank 2 is 4, 5, & 6
Appreciate 2
feuer4275.50
      01-09-2021, 12:25 AM   #4
Louayea
Bank 2 is 4, 5, & 6
Bank 2 is 4, 5, & 6
Lol my mistake I did mean 4,5,6
      01-09-2021, 05:48 AM   #5
Saif2018
973
Drives: E90 335i
Move plugs from 4,5,6 to 1,2,3
If misfire follows, you know its those plugs. If it doesn't then move coils from 4,5,6 to 1,2,3 to see if it follows.
Next thing to check is injectors
Throttle reset should clear the throttle code. Don't turn the car back on immediately, follow the instructions on MHD
      01-09-2021, 07:08 AM   #6
SixSix
19
Drives: (2007 BMW 335i E92)
2002 BMW 325xi  [0.00]
2007 BMW 335i  [0.00]
Its possible that one of your O2s is shot on that bank as they work in banks as well. But I would do what Saif mentioned and move your plugs to bank one, see if it follows and then move your coils to see if it follows. Otherwise it sounds more like a fueling issue. What index injectors do you have?
      01-09-2021, 08:26 AM   #7
mweisdorfer
2008 bmw x5  [0.00]
Yes, the rear O2 sensors monitor fuel trims. If he has turbos that are on their way out & O2 sensors in Catless downpipes, which are older than 100,000 miles, it "could" be a reason for the fuel pump code.
I'd still say to check the plugs, coils & injectors.
There a laundry list of items that "should" be done prior to going FBO and slapping a tune on an N54. If one does all of it, the chances IMO of having issues go down significantly.
The N54 and its DME can be very "fickle". There's 1000's of posts on this forum and others which prove that sentence.
      01-14-2021, 09:49 AM   #8
clegg
87
Drives: 335i E92, 435i F32,X5 F15
Run a bottle of Techron in your fuel tank. My N54 had a missfires that would put my car in limp mode at half throttle. The Techron cleared that up by the time I got to the gas station to fill up.
It's worth a try.
How many miles on the car?
