01-06-2021, 04:25 AM | #1 |
JoseSportM
415
Rep 371
BMW F40 M135i XDrive „Black Sheep"
Hi Guys
I'm glad to present you my "Black Sheep" Ordered in Late November and took delivery on 23. Dezember It was an custom order and it has almost FULL Extras, i didn't want panoramic roof or trailer hitch (if i need this i have on the G05). G05 Black Beast Project So here the Specs: Editions And Packages S704 M Sports Suspension S710 M Leather Steering Wheel S715 M Aerodynamics Package S754 M Rear Spoiler S7CG BMW Repair Inclusive S7M9 Individual Option High-Gloss Shadow-Line S7ML M Performance Package Comfort And Interior Equipment S420 Sun Protection Glazing S423 Floor Mats Velours S428 Warning Triangle And First Aid Kit S430 Interior/Outside Mirror With Auto Dip S431 Interior Mirror With Automatic-Dip S459 Seat Adjustment, Electric, With Memory S481 Sports Seat S488 Lumbar Support, Driver And Passenger S494 Seat Heating Driver/Passenger S4NE Blow-By Heater S4P3 Interior Trim Strips Illuminated Berlin Multimedia S610 Head-Up Display S654 DAB Tuner S688 Harman/Kardon Surround Sound System S6AE Teleservices S6AF Statutory Emergency Call S6AK Connected Drive Services S6C4 Digital Professional I S6NW Telephony With Wireless Charging S6U3 BMW Live Operating Area Professional S6U8 BMW Gesture Control S6WD WLAN Hotspot Driver Assistance And Lightning S534 Automatic Air Conditioning S548 Kilometre Speedo S552 Adaptive LED Headlight S563 Light Package S5AC High-Beam Assistant S5AQ Active Guard Plus S5AS Driving Assistant S5DA Passenger Airbag Deactivation S5DF Active Cruise Control+Stop&Go Function S5DM Parking Assistance System Wheels And Drive S230 Extra Package, EU-Speciifc S248 Steering Wheel Heater S249 Multifunction F Steering Wheel S2NH M Sport Brake S2PA Locking Wheel Bolt S2TB Sport Automatic Gearbox S2VB Tyre Pressure Display S2VE M Sports Steering Environment And Safety S302 Alarm System S313 Fold-In Outside Mirror S316 Automatic Trunk Lid Mechanism S320 Deleted, Model Lettering S322 Comfort Access S3BE Mirror Caps Black S3MF BMW INDIVIDUAL LIGHTS SHADOW LINE S851 Language Version German S879 On-Board Literature, German S8KA Oil Service Interval 24 Mths / 30,000 Km S8R9 Refrigerant R1234yf S8TF Active Pedestrian Protection S8WC Control LC Individual Equipment S760 High Gloss Shadow Line S775 Headlining Anthracite Other Equipment S1AG Larger Fuel Tank S1CB CO2 Equipment S1DF Exhaust Emission Standards EU6 Rde II S1RR BMW Light-Alloy Double Spoke 552M JB S962 Deleted, Licence Plate Support Front SA070 70 Ah AGM Battery So my first impressions to this car are not really "good", i don't know if its only me or maybe is a general situation. First i noticed that the brake feeling is different from other cars i had. The car is new so i will give more time to really make an deeper comment on this, but i noticed that to activate the hold system i need to make a little more pressure in the brake pedal as normal, then when activated i press the gas a little to unlock the hold system then the car jumps to the front immediately and fast. In the X5 i can touch the gas pedal and the system is deactivated but the car dont jumps in the front, it stays in the same place and then it starts to drive slowly, its a lot progressive. It may seem stupid but if you are parking in a small place and the car jumps like crazy its difficult to park and you have to brake hard to not hit the car in the front or to solve this you need to deactivate the hold system. In the G05 its working just fine. Second think that is bothering me is the Aisin Gearbox. Clearly is not as sharp as the ZF8 that i have on the G05. In the beginning is was more dramatic, changing gears is not as smooth as i thought it would be even in Comfort. i think gearbox learns how you drive and seems to be better but i never noticed that on the ZF. Was perfect since 1St Day. Sometimes it struggles to find the perfect gear to the speed im going, also strange to me. Even the DSG from Tiguan i didn't like seems to be smoother than Aisin. But i hope its a matter of time. Unfortunately it is not over, after 100km i noticed that the steering wheel was not right, its slightly to the right and if i center the SW the car drives to the left. Don't want to remember when i had an VW tiguan model 2018, after 50k km i had the same problem and to fix that the VW had to put an new rear axle... No it's not all, the HUD is also not right. the Left side is closer than the right side, the right side is sharp but the left is blurred, that said i can not see the HUD as Sharp as it is on the G05. I made an appointment with BMW and it will go for 1 or 2 days to fix this things. Since i don't like the color of the wheels im testing the wrap film on one wheel. This weeks will be a good test because roads have salt due the Snow, its very cold and then i will wash it with high pressure water. If passes the test i will apply the film on the other wheels. To the summer setup i have some Bola Wheels in Matt black in mind. I noticed also that the Signal recognition works perfect but it doesn't adjusts automatically the speed. i always need to accept manually. In the G05 i have auto adjustment and its just perfect. In this case i will try to find in the coding software the way to code this. It has to be a way to do this, its just annoying to do it manually. I hope this complains and feedback dont annoy you guys. Fell free to comment and share your feedback about everything. Last edited by JoseSportM; 01-06-2021 at 04:34 AM.. |
01-06-2021, 02:54 PM | #3 |
JoseSportM
415
Rep 371
01-06-2021, 03:14 PM | #4 | |
115
Rep 506
i agree with you (and many reviewers) that the gearbox is not the sharpest, i always drive in sport mode and will often go to manual to make it a little more aggressive. in general quite happy with the car. |
01-07-2021, 07:44 AM | #6 | |
JoseSportM
415
Rep 371
You prefer 18 due to comfort? I noticed that you have HR springs, did you notice a change of ride quality from the M suspension? I have Air on G05 so between both cars its a huge difference, but im thinking in maybe lower the F40 but its already very hard with the M suspension. |
01-08-2021, 08:15 PM | #7 | ||
225
Rep 342
01-10-2021, 05:17 AM | #8 | |||
JoseSportM
415
Rep 371
I don't want that on F40. I think I will try one of these eibach or dähler |
01-10-2021, 02:16 PM | #9 |
Rep 6
Hi there, very nice car !
I do have the same wheel and I would like to get it black too. what vinyl did you buy to wrap it ? How did it go with the high pressure water ? Thanks ! |
01-11-2021, 02:16 AM | #10 | |
JoseSportM
415
Rep 371
If im not wrong i have Hexis with rapid air film, but i'm not sure, i can confirm you later. i did a few wrapping jobs in the past and i had this foil in the garage. For now its holding good even with -8 degrees. I will wash them later this week. |
01-11-2021, 10:43 AM | #11 | |
Rep 6
So how did you cut the vinyl ? I thought it was already pre-cut. Ok, please let me know how the wrap handles the water pressure Have a good day! |
01-14-2021, 03:44 AM | #12 | |
JoseSportM
415
Rep 371
I did the vinyl design myself, only prototyping. If works i will design it in illustrator and cut it with a cutting plotter. The vinyl is HEXIS | SKINTAC | HX20889B | Coal Black Gloss |
01-14-2021, 10:49 AM | #13 | |
Rep 6
Thanks for letting me know ! That is actually very nice. Is it easy to do it by yourself ? I've asked my garage, it cost 160€ per wheel for the covering and to paint it it is actually the same price.. |
01-14-2021, 01:26 PM | #14 | ||
225
Rep 342
01-15-2021, 01:10 AM | #15 | |
JoseSportM
415
Rep 371
Here in Switzerland they ask for 400chf painting. As i have foil i can try it for free but i think they would ask me in the garage also almost the same price as painting. |
01-15-2021, 03:58 AM | #16 |
Rep 6
incredible, it looks good even with the heavy snow :O
Can you even see the difference between the wheel and where you applied the vinyl ? I will maybe try to do it myself.. |
01-15-2021, 05:02 AM | #17 | |
JoseSportM
415
Rep 371
When i had this problem with the steering wheel, they called me and they told me that one wheel was different, they didn't notice that was the same but wrapped, so.... In my eyes i see the difference but in others eyes don't I must say the Xdrive works very very well, in the company parking lot some of my colleges could not park the car with this amount of snow and i did without problems. I drive with dsc off (tracktion mode on) with this amount of snow. Last edited by JoseSportM; 01-15-2021 at 05:07 AM.. |
01-15-2021, 08:24 AM | #18 | |
Rep 6
Well at least on the pictures, you don't see the difference with the wrap good job there ! you only used the wrap and a heater gun right ? Xdrive is defintely a + in switzerland haha ! |
01-16-2021, 06:27 AM | #19 |
115
Rep 506
on a slightly different note, what tires are you running in the snow? i am think of a mountain road-trip in the coming weeks. thanks!
