Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 30bb code (MSD80) after replacing all parts
      01-05-2021, 06:19 AM   #1
antoniog
Drives: bmw 325i
Hi all,
I can't clear 30bb code even after installing all new parts:
- new injectors (index 11)
- new coils
- new spark plugs
- DME (MSD80) was tested using hardware in loop by the ECU testing company and it's 100% functional (also tested the mosfets and they are good).
I've tested the wires (from DME to injectors) and the ground and everything is fine...
The only thing I can think of is timing chain...
Can a jumped chan cause the unremovable 30bb code?
      01-05-2021, 09:40 AM   #2
lookalikehuuh
Drives: 2006 330i, 2007 335i
This guide seems to be pretty comprehensive for 30BB codes
https://us.autologic.com/news/bmw-ms...ector%20driver.
      01-05-2021, 10:30 AM   #3
antoniog
Drives: bmw 325i
I've followed this guide...
Wires are in good condition (tested using voltage drop test).
Mosfets are good (disassembled ecu and tested using multimeter).
I have even sent the DME to a specialised ECU testing company and they confirmed the DME is working fine...
      01-05-2021, 10:36 AM   #4
lookalikehuuh
Did you try the Oscilliscope to map the signal that is being sent to the injectors?
      01-05-2021, 05:41 PM   #5
feuer
feuer's Avatar
Drives: wife crazy!
I had this happen. Replaced all 6 Mosfets and was still getting 30bb and misfire on cyl 6 I think. Ended up installing msd81. This was in 2018. Still runs ok.
      01-06-2021, 01:42 PM   #6
antoniog
Drives: bmw 325i
Can't start the car and therefore not possible to use oscilloscope...
      01-06-2021, 01:53 PM   #7
antoniog
Drives: bmw 325i
Will MSD81 fit the N53 engine (non-turbo)? Currently I have MSD80 one.
      01-06-2021, 04:56 PM   #8
feuer
feuer's Avatar
Drives: wife crazy!
Yes, newer 330i n53 came with msd81
      01-10-2021, 04:23 PM   #9
antoniog
Drives: bmw 325i
Thank you! I'll try the msd81 upgrade and will post an update in this thread soon.
      01-25-2021, 05:45 PM   #10
antoniog
Drives: bmw 325i
Upgraded to msd81, the 30bb code is gone but now getting 2E30 code and the engine is running in "half power" mode...
      04-21-2021, 07:37 AM   #11
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
feuer where did you source msd81?
      04-21-2021, 11:07 AM   #12
feuer
feuer's Avatar
Drives: wife crazy!
This was years ago. DHGate I believe.
Tags
30bb, dme, injectors, msd80
