12-31-2020, 09:40 PM | #1 |
34
Rep 42
Ultimate OEM 395mm Brake disc upgrade for our cars? (w/pics !)
since someone already posted that the 5 series brake calipers fit our cars, along with the 395mm wopping big dimpled and slotted 395mm discs
as posted here: https://g20.bimmerpost.com/forums/sh....php?t=1751100 I was considering this upgrade but didnt want the extra weight of the upgrade, and was willing to wait until the aftermarket caught up with 2 piece units. but was looking and waiting and saw Alpina is offering these 2 piece units that are stock on their B3 cars and im assuming it has a part number associated with it. with actual holes instead of dimples and the 2 piece aluminum rotor design, i'd figure it would weigh as much as the stock m-performance discs. Even the rears get the cross drilled action but this pic of the configurator is all i could find on the rear. and THAT also looks 2 piece as well. could these be re-branded next gen M3 discs with just the alpina logo? ( looks like the next gen m3/m4 will have different calipers though) |
01-07-2021, 11:26 AM | #2 |
1109
Rep 612
These are just ///M 395mm discs that have been rebranded by Alpina - the drilled nature is identical to the ///M discs.
X3M / X4M ///M discs fit the G20 G30 etc with the use of the 4 pot 395mm caliper - the issue is that the retaining screws do not line up with the non M hubs. Everything else is perfect thought, I have checked. Alpina have obviously fixed this, and these would be the "perfect" solution for a pure plug and play solution. The issues are: a) finding the part number - I emailed Alpina in Germany months ago and they won't divulge it. b) even if you manage to get it - they will only supply to owners who can provide a VIN number / proof of ownership |
01-07-2021, 06:13 PM | #4 |
1109
Rep 612
They will have the same issue with the retaining screw not lining up. The ///M cars have M specific hubs. On top of that, the G80 discs will quite probably be the wrong offset as the incoming M3 uses the same 6pot caliper as the F90 M5.
Which will use a radial bracket mount to fit to the G80 hub, in the same was as the X5m does. Interestingly, you can mount the F95 X5m 6 pots onto G20 hub (as it comes with a radial bracket from factory) in conjunction with X3M 395mm discs and it fits with only a very small amount of adjustment needed. |
01-07-2021, 06:29 PM | #6 |
1109
Rep 612
01-08-2021, 12:24 AM | #7 | |
378
Rep 598
Thnks sir
08-26-2022, 07:14 PM | #8 | |
149
Rep 235
08-26-2022, 07:40 PM | #9 |
331
Rep 468
Drives: G20 330i xDrive M-Sport
I know this is a dumb but I kind of want Alpina hubs haha
08-26-2022, 08:32 PM | #10 |
3584
Rep 3,984
does anyone know - i've always wondered if you put stronger, larger, different spec brakes
does the ABS and stability control need to be reprogrammed? this has always stopped me putting bigger rotors |
08-27-2022, 07:10 PM | #11 |
37
Rep 88
I assume these would require 20" wheels given that the M Performance 374mm ones barely fit in a 19". I could also imagine this has some impact on the caliper mounting that would need to be worked out. Oddly the calipers in the picture actually look the same as the M-Performance ones (Brembo rebranded 4 pot and similar shape) just on a bigger rotor with cross drilling.
09-01-2022, 12:47 PM | #12 | |
1109
Rep 612
The caliper bodies are different when you see them side by side but you are right in the fact that they look super similar! |
