N54 silicone inlets - Questions
12-27-2020, 08:53 PM | #1 |
113
Rep 513
Drives: 2008 335i
Hi Guys,
I just took off my tranny to change my clutch, and after I got the clutch off, I see there is some damage developing on my pretty new silicone inlets. These are VRFS inlets. Also, I've attached two pictures. One is showing what looks to be a crack or a cut, and the other is showing how crazy squished this inlet is. I wanted to know if these cracks are common, and if applying glue would suffice to fix it, also what kind of glue I should use for the repair. Lastly, look at how squished that inlet tube is between the car body and the engine/transmission. I know it's a tight fit there, but is that amount normal? Thanks for your input! |
12-27-2020, 09:41 PM | #2 |
1044
Rep 1,667
Everybody knows there are no issues with any VRSF parts. This is clearly a case of installer error. Sorry I can’t be any more helpful OP...but this is the way...
_N54299.50 1Bad335turbopsi57.50 |
12-27-2020, 11:15 PM | #5 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
When you installed them, did you lather rear inlet up with soap or synthetic grease? Also, you can create some room back there by taking off the OEM inlet bracket. Some of the edges back there are sharp; you could tape the new one up with gorilla tape in areas you think the inlet might contact, that are sharp. You could also file down edges that are sharp & round them off.
12-28-2020, 02:00 PM | #6 | |
113
Rep 513
Drives: 2008 335i
Installed by a well knowing bmw specialist mechanic too. |
Bimmer_Engineer1043.50 |
12-28-2020, 02:01 PM | #7 | |
113
Rep 513
Drives: 2008 335i
12-28-2020, 02:03 PM | #8 |
113
Rep 513
Drives: 2008 335i
12-28-2020, 02:26 PM | #9 |
1044
Rep 1,667
I was totally being sarcastic...and FWIW if it were me I would totally replace them now as it's way easier with the car in the current state. I can't make a recommendation on what to replace with, but there have been a fair number of posts on here regarding collapsed VRSF silicone inlets...
12-28-2020, 02:40 PM | #10 |
3441
Rep 79,211
If they rub anywhere, anytime that engine flexes(which is often) it will wear through. A lot of the damage on that looks to be during install.
12-28-2020, 06:19 PM | #11 |
147
Rep 517
I have installed RB inlets on two cars, one car I left the stock inlet bracket on, the other one I took off. The car with the inlet bracket still on was a much tighter fit, I would suggest taking it off before you reinstall a new inlet. Also make sure to lube inlet before install to insure it doesn't catch on something sharp.
12-28-2020, 06:42 PM | #12 |
300
Rep 884
Yup replace them. I would get the RB's if I had to do it all over again.
2013 335is - sold
2011 335d |
12-28-2020, 06:49 PM | #13 |
75
Rep 231
12-28-2020, 07:29 PM | #14 |
720
Rep 946
Suggest using hairspray to install the new inlet. Trick i used to do years ago with bike grips. Slides on with ease and within 24hrs itll dry unlike grease or anything
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
