Juddering Idle & Fluctuating Voltage
12-24-2020, 03:51 AM | #1 |
Rep 94
Hi all,
Recently changed all my coilpacks to Delphi 10572's and OEM Bosch spark plugs. On idle the car shakes considerably and the voltage measured through the OBD is all over the shop going from 11.9 to 13.8v. Also noticed my glovebox light dimming in time with the shuddering. A new alternator was fitted by BMW 7 months ago along with a new battery. Only mod is MHD stage 1+ and I get no fault codes whatsoever. Reading online that I may have fake Delphis? (black epoxy instead of white). Any ideas? Last edited by snaeem155; 12-24-2020 at 03:58 AM.. |
12-24-2020, 04:31 AM | #2 | |
973
Rep 3,219
Also where did you get the coils from? Whats your idle speed? |
12-24-2020, 04:58 AM | #4 | |
973
Rep 3,219
Also check the battery voltage directly if that doesn't make a difference. If you had a good set of coils, you could have swap them out to check. |
12-24-2020, 05:11 AM | #5 |
Rep 94
I'll adjust the idle today and measure the voltage at the battery and see how I fare.
The coils are probably less than 150 miles old, blew one of the OEM Bosch ones soon as mapped stage 1 hence the replacement. The juddering is deffo worse after installing new spark plugs. |
12-24-2020, 06:24 AM | #6 | |
973
Rep 3,219
Let us know what happens when you try the above. |
12-24-2020, 06:41 AM | #7 |
Rep 94
If it helps I just did an idle log with a few seconds holding it at 1krpm.
https://datazap.me/u/snaeem155/idle?log=0&data=1-12 On starting the ignition the battery voltage was at 11.17v. Its a new battery not even 7 months old. |
