Should I get inlets if I am on pump gas only?
12-22-2020, 06:28 PM | #1 |
13
Rep 136
Planning to get a 135i soon and am in the process of researching mods. I want to get the VSRF OEM location inlets along with FBO but I read somewhere the silicone ones are bad. Would I get any gains if I am only using pump 94? I am mostly looking for top end gains here as that's where the stock turbos start to fall off.
12-22-2020, 07:33 PM | #2 |
321
Rep 751
It won't hurt but they are a real pain in the ass to install. I had a bad experience with vrsf inlets, get either bms, rb or precision raceworks inlets.
You are still going to lose power at high rpms on stock turbos even with the inlets though. |
12-22-2020, 07:43 PM | #3 |
13
Rep 136
Will the inlets at least improve top end? Also if that's the case what rpm should I shift at?
12-22-2020, 07:51 PM | #4 |
234
Rep 317
Think of inlets as a reliability mod. They reduce restriction in the intake path which makes it so the turbos don't work as hard. I don't think it will change your top end power much, besides allowing for running a tad more boost if on stock turbos.
I wouldn't worry much about the brand either - they all suck to install. Fuck that rear inlet connection, it's a bitch. |
12-22-2020, 08:24 PM | #6 |
13
Rep 136
Ah i see, so redline shifts aren't good with this car. So, would adding inlets hamper my top end? Or will it just increase my hp and torque everywhere? How will it affect the powerband?
12-22-2020, 09:56 PM | #7 |
300
Rep 884
Inlets will make a difference regardless what fuel you're running. Your turbo will be much happier not working as hard and you will gain torque and some horsepower. Silicone inlets are bad? That's pretty much the only thing on the market available for stock location. I have the 2" VRSF myself and I also have the VRSF outlets, but haven't installed it yet.
2013 335is - sold
2011 335d |
12-22-2020, 10:14 PM | #8 | |
13
Rep 136
12-22-2020, 10:25 PM | #9 | |
300
Rep 884
Here's something I found on YouTube:
2013 335is - sold
2011 335d |
12-23-2020, 06:57 AM | #10 |
720
Rep 946
I have 2in inlets from mmp and theyre great especially at reducing WGDC and even with OTS maps i’m running 2psi more than the equivalent fbo car would without. However to take full advantage of inlets you need a custom tune
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
12-23-2020, 08:46 AM | #11 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Inlets are beneficial either way
12-23-2020, 03:38 PM | #12 | |
13
Rep 136
12-23-2020, 04:18 PM | #13 | |
973
Rep 3,219
Low to mid is the biggest improvement though, watch the first video Outlets don't make much of a difference, but inlets make a big difference. |
12-23-2020, 11:11 PM | #14 | |
300
Rep 884
2013 335is - sold
2011 335d |
12-24-2020, 01:36 AM | #15 |
973
Rep 3,219
12-24-2020, 10:25 AM | #16 |
195
Rep 305
Inlets are one of the most beneficial mods IMO.. that and Downpipes. I noticed a big difference.
08 E90 335i - MONTEGO BLUE
JB4/MHD E85 BEF - RB TWOS PLUS ECS CARBON DCI - BMS CHARGEPIPE NRW CARBON COWL FILTERS - TIAL BOV VRSF 7.5 RACE FMIC - VRSF INLETS - VRSF OUTLETS - VRSF DOWNPIPES BMS PEDAL TUNER - VTT DUAL CATCH CANS 3.5 BAR TMAP - NGK 97506 PLUGS H@R SPRINGS - NRW V1 PADDLES PFS STAGE 3 LPFP - PFS V2 PORT INJECTION MOSSELMAN OIL THERMOSTAT MISHIMOTO 25 ROW OIL COOLER SPOOL PERFORMANCE ETHANOL ANALYZER MISHIMOTO 15 ROW TRANSMISSION COOLER ZIMMERMAN DRILLED ROTORS - EBC REDSTUFF PADS |
12-24-2020, 10:39 AM | #17 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
Yes. They are relatively inexpensive but a pain to install. You will want a custom tune to take real advantage of them. If you want more gains run meth and add outlets, that is going to max out your stock turbos on pump gas non 85. I would do all 3 and then start custom remote tuning.
I have held or seen most of the inlets on the market. The RB inlets are the highest quality along with PR but you pay for them. I always recommend the PR passenger side inlets as it cleans up the engine bay and you need to move your coolant tank anyways when your upgrade to a single turbo
12-24-2020, 10:42 AM | #18 |
75
Rep 231
Agreed, i noticed increased power throughout the rpm range. I installed the RB inlets, wasn't that bad to install them. Need to craft up a small wrench and torx bit to get to the screws holding the rear inlet, and even that wasnt difficult imo.
