Twin turbo or Single turbo for 550whp?
12-20-2020, 02:17 PM | #1 |
13
Rep 136
Should I go with twins or a single for this power goal? I wont be running e85 so I need some help with picking fueling mods. Do I need PI at this whp? Also, should I run meth or not?
12-20-2020, 04:55 PM | #2 | |
393
Rep 972
Maybe meth would help but I am no expert with meth kits. Have your purchased a 335i yet?
Instagram : @Bimmer_bro
12-20-2020, 06:12 PM | #3 |
13
Rep 136
No sir, simply planning and looking at options and figuring out what I would like to do. Would I need PI at this hp level?
12-21-2020, 07:13 AM | #5 |
720
Rep 946
What are you planning to do with the car and what kind of powerband do you want?
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
12-21-2020, 06:28 PM | #6 |
147
Rep 517
I plan to be hitting somewhere around 500 with RB twos on pump, but I've been told that's about as far as I can go without higher octane. So you will definitely need meth to get above this number, but once you have it you can probably go farther than 550..just depends how much meth you want to spray(how much money you want to spend)
12-21-2020, 09:54 PM | #7 |
2659
Rep 6,290
Following. Would like 550whp to with twins with no E85 (No E85 at gas stations). Figured meth but it seems expensive for the 100% safe systems...
12-21-2020, 10:41 PM | #8 | |
455
Rep 875
Didn't look like he needed meth |
12-22-2020, 08:23 AM | #9 |
BimmerPost Supporting Vendor
24199
Rep 190,807
twin-turbo for the extra tq
12-22-2020, 12:50 PM | #11 | |
2001
Rep 3,731
Meth systems just add more components that can fail. |
12-22-2020, 04:00 PM | #12 | |
2659
Rep 6,290
12-22-2020, 04:48 PM | #13 |
2001
Rep 3,731
Probably none....or very little. It's more to cool the intake charge down on hot days (the top mount intercoolers on those heat soak really bad) to keep it from having a bunch of timing corrections, and bump up the octane a little bit for when I can't find 93 fuel. It actually does what it's supposed to...most of the time.
12-22-2020, 06:25 PM | #14 |
13
Rep 136
12-22-2020, 06:26 PM | #15 | |
13
Rep 136
12-23-2020, 12:35 AM | #16 | |
2659
Rep 6,290
12-23-2020, 06:53 AM | #17 |
720
Rep 946
Single turbo then. For what its worth. Not saying it would be the safest setup but recently with a 6466 they hit 670whp on 94pump gas. So 550whp with a single turbo on pump is doable. With the correct turbo size of course.
I would recommend checking out other forums such as SS for more info on ST setups though rather than here.
04-17-2021, 07:07 AM | #18 |
Rep 4
Im pushing 556whp on the dyno.
This is the mod/upgraded/maintenance list Vrsf Chargepipe Tial BOV ARM 7” Intercooler w/ Upgraded Hoses MMP Catless Downpipes SSR DCI XHP Trans Tune Stage 3 BMP Stage 3 Dual Walbros 450s w/ Boost Ref Harness & Hobb Switch E85 MHD Custom Tune N20 3.5 Bar Tmap Sensor VRSF 2” Inlets NGK 97506 Gapped to .22 Precisión Raceworks Coil Plugs VRSF Oil Catch Can RB Turbo Upgraded PCV TD04-19T Upgraded Twin Turbos (EBay Turbos)(Still running great after 12,000 miles :0 ) BMP Port Injection kit W/ AIC 6 Controller Precision Raceworks Feed Fuel Lines Rear tires (265/40/19) (Michelin PS4 S’s) I abuse the car on the daily , just make sure you do all maintenance beforehand so you won’t be left stranded. With this installed, you’ll gap many people |
04-17-2021, 08:19 PM | #19 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
