12-19-2020, 01:24 PM | #1 |
BimmerPost Supporting Vendor
24204
Rep 190,807
ARM Motorsports S55 J-Pipe ***NEW PRODUCT***
HIGHLIGHTS • FULL T6061 ALUMINUM CONSTRUCTION • SECURED THROTTLE BODY CONNECTION • DIRECT FIT PROFILE Complete your S55 upgraded charge piping with the ARM S55 J Pipe! This J Pipe is the final piece of piping on the S55 before the charge air enters the intake manifold. BMW constructed the OEM J Pipe of plastic which is prone to cracking an detaching from the throttle body under boost. The ARM S55 J Pipe is constructed of T6061 aluminum for a durable replacement that will hold up to even the most demanding builds. The ARM S55 J Pipe is designed to lock onto the stock throttle body using a CNC machined connector. This connector incorporates a locking C-clip design which replaces BMW's one-time use plastic strip to create a secure connection to the throttle body. Included with the ARM S55 J Pipe is a pre-plugged 1/8 NPT fitting which allows for post-intercooler methanol or nitrous injection. This is the preferred location of injection for many S55 tuners. For reinstalling your S55 vacuum line, the ARM J Pipe has a precisely machined vacuum line connection port to prevent any leaks, a common issue on many other S55 J Pipes. IN THE BOX • ARM S55 J Pipe • Intercooler To J Pipe Silicone Hose • Throttle Body Retaining C-Clip • Replacement O-ring • Clamps FITMENT GUIDE
ARM MOTORSPORTS LIFETIME WARRANTY Every ARM Motorsports product is backed by a lifetime warranty which is automatically issued at the time of purchase. Your warranty protects you against any defects in craftsmanship or fitment. The warranty entitles you to a replacement unit.
