12-14-2020, 09:09 PM | #1 |
57
Rep 299
420801 - Transmission fault code help
hi all
anyone has this code before? 420801 - Electric motor clutch 2 sensor: Supply short circuit to B+. What does it mean and is it anything i need to worry about? thx
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
12-15-2020, 02:21 AM | #2 |
Rep 20
I'd like to know as well, I had the same shadow code. I just had a transmission replacement done with a brand new unit, 2016 340i
12-15-2020, 02:25 AM | #3 | |
57
Rep 299
What symptoms have you noticed? My car seems to drive OK except I've kind of noticed it feels like the gearbox disengages and there's a hesitation to re engage when I get back on the gas. Is there confirmation what is meant by a "shadow code"? From google, some says its like a preliminary code when the car is yet to confirm it as a fault while others have said it's like cache memory |
12-15-2020, 02:29 AM | #4 | |
Rep 20
After the replacement the noise is gone, shifts are much better, but I noticed this shadow code. I cleared the code and it hasn't re-appeared yet. I couldn't find any info on the net about this code. |
12-15-2020, 02:40 AM | #5 |
57
Rep 299
Thanks for sharing. I've just hit 20,000 km so relatively low mileage and I dont drive it very hard apart from the occasional boot down a local street.
For me there were 2 records of the shadow code. Do you have any other error codes? I got the below 4203F1 unknown 420801 - Electric motor clutch 2 sensor: Supply short circuit to B+. 420822 unknown 421732 unknown |
12-15-2020, 02:42 AM | #6 |
Rep 20
I had the 420801 exactly like yours with the same description
I also had 421062 - unknown Would love to find info on this if possible before I flash MHD and XHP |
12-15-2020, 02:44 AM | #7 | |
57
Rep 299
I've emailed the dealer to ask what I should do given there were codes which I've since however cleared Shall report back with updates |
12-15-2020, 04:37 PM | #10 |
809
Rep 1,597
Looks like the code has to do with gear engagement and your sensor for clutch 2 looks like its gone bad. Now I've never heard of a sensor on each individual clutch plate so I would imagine this is indicating mechatronics maybe one of your solenoids is on the way out. That would sound more reasonable to me and why so many of you have this code since its a part which known to wear. Your shadow codes could have to do with your AT unit exceeding ratings and may have to do more with your tunes.
12-22-2020, 11:59 PM | #13 |
Rep 20
A BMW techie replied to me, he said not to worry since it is shadow codes, and could be related to adaptations.
I have cleared my codes using MHD a couple weeks ago, it hasn't returned since. Car moves and shifts perfectly fine. I'm 100% stock as well, never tuned. |
01-02-2021, 06:01 AM | #14 |
64
Rep 348
Anyone have 421892 shadow code? Car flashed with xhp stage 3
Pure800 - DS2 HPFP - Nostrum S1 - ER Catless DP - Remus Non-Resonated Catback - BM3 Flex Fuel Kit - Ross V1 VTA PCV - Custom Tunes on MHD/BM3 - xHP Stage 3 - TCKline SA/DA Coils - Apex ARC8s - Vicrez Carbon Fiber CSL Trunk - ALP Laser System - Escort Max 360c with Blendmount + more... | IG: kianf22 |
09-13-2021, 02:08 AM | #15 |
Rep 27
Updating this post to help anyone with similar transmission codes. I bought my 2016 340i at 40k miles, and pulled these codes at 50k:
420801 - Electric motor clutch 2 sensor: Supply short circuit to B+ 421732 - Unknown I replaced the following with 100% oem parts in hopes to fix the codes. Also ZF recommends this done every 50k miles, less if tuned: transmission pan/filter oil mechatronic sleeve 7 months later and still no codes. 6 months with xhp stage 3 on mhd e40 tune, trans runs flawlessly. I really recommend only using oem parts/fluid. |
