Which oil catch can you got??
12-14-2020, 07:24 PM | #1 |
Hey, where have you been all my life?
680
Rep 1,401
Anyone running these Amazon catch cans??
It's only $24, yet has 4.5 stars @ 1,700 reviews? What makes a Radium, BMS, Turner or ECS catch can better?? (and justify $180?) Anyone running these or something similar? https://www.amazon.com/dp/B06XK9PTP7..._V9a2Fb995X9DP |
12-14-2020, 09:57 PM | #2 |
2001
Rep 3,731
I have one....as far as I can tell, same as all the others. Haven't installed mine yet though.....
SilverSlug680.00 |
12-14-2020, 11:37 PM | #3 |
1209
Rep 2,476
It'll probably work just as well as any of the "brand" names, as long as it's machined well. Hose bung hole threads and waste oil cup threads... if those are poorly machined it'll just be a PITA. Assuming they're ok with so many positive reviews.
With that said, these types of cans that work on boost/high side really aren't worth the effort and cost. They catch practically nothing. What you want is to externalize the PCV and use the Mishimoto can on the vacuum/low side. This is where you spend the majority of the time while driving and it will be much more effective. Google "RB external PCV" for more info, and get the can that is suggested for that system - it works. |
SilverSlug680.00 |
12-15-2020, 12:02 PM | #4 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
12-15-2020, 12:35 PM | #5 |
329
Rep 603
I've had the same question. I'll Google that RB external PCV. Thanks Emilime75
SilverSlug680.00 |
12-15-2020, 12:36 PM | #6 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Is this for the M3 that you have listed? Totally go for it, and post results on the M3 forum
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
SilverSlug680.00 |
12-15-2020, 01:34 PM | #7 | |
680
Rep 1,401
Not too many people run them on the S65, so I wanted to ask the hot blood turbo crowd about build quality and efficiency of these amazon ones. I'll definitely post the results though! I'm still shocked at the markup of the ECS and Turner units... Has anyone else installed one of these Amazon ones? |
12-15-2020, 02:33 PM | #8 | |
1209
Rep 2,476
With that said, since the OP is asking about these for a completely different motor... |
12-15-2020, 04:26 PM | #10 | ||
680
Rep 1,401
And where would the ideal place be to install it on an S65 engine? |
12-15-2020, 06:24 PM | #11 | |
88
Rep 352
12-15-2020, 08:36 PM | #12 |
1903
Rep 6,968
12-16-2020, 11:36 AM | #13 | |
2685
Rep 4,202
This is for the n54 which is turbocharged my dude, you're NA. You're asking n54 guys about the s65, we got no answer for you. From what I saw you guys don't even have a dedicated catch can, others have just jimmied it up.
SilverSlug680.00 |
01-06-2021, 02:32 AM | #14 |
680
Rep 1,401
Ya I know NA engines may not see as much benefit from a CC, yet the ones that have them installed, still drain oil/liquid out of them.
Thanks for answering my question though - the Mishi CC has a finer mesh. |
01-06-2021, 08:43 PM | #15 |
300
Rep 884
I just have the BMS vacuum side oil catch can. Catches a ton of oil. Majority of the time the car is under vacuum when you're idling and cruising so it helps to have one. I also purchased a high side oil catch can that sits on the passenger side from ECS, but its backordered until March so Ill need to cancel that and look for something else.
2013 335is - sold
2011 335d |
01-07-2021, 07:56 PM | #16 |
79
Rep 273
Many of the ones on the market (that aren't custom) work about the same as they typically are (just rebranded).
Here are a couple I made for my cars and work excellent.
2008 BMW 135i - VRSF Race FMIC - VRSF Charge Pipe w/ Tial BOV - 3.5" Downpipe - SM Exhaust - SM Top Mount w/ BW S366 - 450 & 525 bucketless - SMS Catch Can - SMS Oil/Trans Cooler
Facebook.com/SpoolnMotorsports |
01-07-2021, 08:08 PM | #17 |
479
Rep 1,196
I do like my RB external setup. I don't run a high side currently because the amount of oil caught while running an external low side setup is minimal.
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
01-07-2021, 09:18 PM | #18 |
321
Rep 751
That's weird, I barely catch anything from my bms high side catch can but my rb external low side needs to be emptied about every 500-700 miles or so.
01-08-2021, 09:45 AM | #19 |
300
Rep 884
Most of the time you're in vacuum when cruising that's why it catches a lot of oil. I only have a low side catch can, but will install high side later when I upgrade my turbos.
2013 335is - sold
2011 335d |
01-08-2021, 12:50 PM | #20 | |
479
Rep 1,196
2009 BMW 335i 6MT
